This is for a Friend in Utah (GO BYU!!) that is making CUSTOM EB Parts. I have talked to Matt a couple times and think I will get my Bumpers and Family Cage from him. I go to Utah about every other month and can bring back items to the group. I will try to get his Email address as well. Matt is a in the Chemical Engineering Program at BYU (GO COUGARS!) and doing this to help pay for school and fuel his passion for Classic Broncos. I included a couple pics of his work and hope to post more.
Here is Matt's Ad:
I am a certified welder. I have done 3 bronco restorations from the frame up, including fabrication of all suspension components. I have built just about anything you can imagine either for my own broncos or for customers.
-Extended radius arms- This will improve your handling on the road, increase the softness of ride and dramaticaly improve offroad performance by increasing articulation
-Axle swaps- replacement of the dana 30 with a dana 44, high pinion 44/9 inch combo for better pinion/castor angles and added strength, dana 60/14 bolt combos for the ultimate in strength.The wide stance makes your squirly bronco incredibly stable.
-Suspension lifts- aftermarket dealers are basically making a killing of their products, I can lift your rig for a fraction of the price and give you the same performance.
-Traction control-for those of you with axle wrap, I make a traction bar almost identical to james duff, but with heims so you don't inhibit articulation.
-Shackle flips, trac bar risers, heim joint steering, power steering conversions, disc brake conversions, body lifts, roll cage fabrication. If it has anything to do with a bronco, I can do it.
-Bumpers are custom built to your specifications, most clients find pictures on the internet of bumpers they like and We make them for a fraction of the cost, saving you money on the product and shipping.
Optional features include:
-reciever in rear or front
-tow hooks, or clevis
-swing out tire racks
-spare gas can racks
-tubing brush gaurd, pre runner style
-winch mounts
-tabs for tow bar
-wrap around design
-body lift options(bronco pictured has 3 inch body lift, go ahead and try to find something on the internet that looks that good)
-All bumpers come painted with ppg base coat clear coat.
Cedentials: Certified welder, 3 frame up bronco restorations, dozens of satisfied customers. If you want pictures of past work, give me a call.
For questions, call Matt at 208-954-0079
