Register •
FAQ
• Login
It is currently Fri May 10, 2024 2:10 am
[ 3 posts ] |
sykanr0ng
Time is an hour off
The time when the forum says I just made a post is an hour later than any clock I have and the time I just checked on the internet.
Sat Dec 12, 2015 12:36 am |
Re: Time is an hour off
Sat Dec 12, 2015 12:37 am |
Yes under the CP you can adjust the time. there is a box for daylight savings that if checked time will be off. You have to check/uncheck the box at each time change.
Sat Dec 12, 2015 9:02 am |
[ 3 posts ] |
