Mini Starter & JB Fab Twin Sticks
Non-Bronco related For Sale area. Because you'd much rather deal with someone you know than some flake on Craigslist.
Postby Kinder » Thu Jun 11, 2020 1:45 pm
A couple of items that can’t be used on the 5 speed swap for TFB.
$100 - Made in the US Ford mini starter for an automatic, not re-manufactured so it actually works. Based on what the internet says it can be used with a standard transmission as long at it’s a 157 tooth flywheel.
$100 - JB Fab stainless steel twin sticks for a J shift D20 that bolts to the factory adapter in front of the D20. They will come with new ball style shift knobs and not the mismatched set pictured.
Re: Mini Starter & JB Fab Twin Sticks
Postby la hi » Fri Jun 12, 2020 6:02 am
I don't want to cut your thread but? I don't know how twin sticks work. What are they good for? Will they make the dana 20 shift easier? Will someone show me where an article on twin sticks can be found?
thanks,
larry
66 u14 built in jan 66 original transfer case
la hi
Postby Jesus_man » Fri Jun 12, 2020 9:56 am
Twin sticks allow you to control the front and rear axles independently. You could thru the rear in N and the Front in L and do a front dig. Also, they can help shifting the t-case in general.
https://www.wildhorses4x4.com/product/S ... 0_Shifters
Postby la hi » Fri Jun 12, 2020 11:40 pm
Thanks
la hi
Return to Misc For Sale
