A bunch of Dana44 Axle Shafts - Various lengths
Non-Bronco related For Sale area. Because you'd much rather deal with someone you know than some flake on Craigslist.
Postby landshark » Sun Feb 14, 2016 8:59 pm
I have a few different axle shafts from several different Dana 44 equipped trucks. I don't remember exactly where they are from but know one set is probably from full width F150 or F250, probably 74-77. I can take measurements if needed, tried to provide some in the pictures below. Willing to take what you think they are worth - let me know.
Re: A bunch of Dana44 Axle Shafts - Various lengths
Postby Kinder » Mon Feb 15, 2016 8:43 am
Can you put together a bronco set from all your pieces? I don't have the measurement off the top of my head, but Zac needed a complete set.
Postby landshark » Mon Feb 15, 2016 9:43 am
kinder wrote:Can you put together a bronco set from all your pieces? I don't have the measurement off the top of my head, but Zac needed a complete set.
I dont know if any of these will fit an EB, the outers maybe...
i will look for measurements
Postby Kinder » Mon Feb 15, 2016 10:23 am
I've got a trail spare set, I'll dig them out & measure as well.
Postby landshark » Mon Feb 15, 2016 12:32 pm
I do too. Just remembered. Will take measurements tonight and let you know.
Postby landshark » Mon Feb 15, 2016 9:56 pm
Pulled out my backup front axle shafts and took some measurements.
Looks like these four outers are the same size
But the short side inners are not - one is 1/4" longer the other about 1" longer.
EB Inner length is 16.5"
One is 16.75"
two are 17"
The long side inner is way too long, not even close to a EB axle.
Don't know if that was helpful. one set of driver side might work. three of outers look to be a match.
let me know would love to get these out of my garage or i might turn them into art.
Postby Justin » Tue Feb 16, 2016 8:46 am
Outers should be the same between the EB and F150/Bronco axles (9 23/32" long as measured from the end of the axle to the center of the u-joint cap). Do you have any inners that are 18 29/32" and 33 29/32"? If so I'll take a full set. Otherwise I'll take one of the outers. I'm assuming the shiny aftermarket stuff in the pic is your spare?
Postby Kinder » Tue Feb 16, 2016 12:07 pm
Set aside a couple of outers and the one inner that is close for Zac, I'll work on meeting up.
Postby landshark » Tue Feb 16, 2016 3:44 pm
kinder wrote:Set aside a couple of outers and the one inner that is close for Zac, I'll work on meeting up.
Ok
Postby landshark » Tue Feb 16, 2016 3:52 pm
Justin wrote:Outers should be the same between the EB and F150/Bronco axles (9 23/32" long as measured from the end of the axle to the center of the u-joint cap). Do you have any inners that are 18 29/32" and 33 29/32"? If so I'll take a full set. Otherwise I'll take one of the outers. I'm assuming the shiny aftermarket stuff in the pic is your spare?
One set inner 34 29/32 with outer at 10 3/4 or so
One set inner is 18 29/32 outer is 9 23/32
One set inner about 19 outer is 9 23/32
One inner at 18 29/32
Two outer at 9 23/32
I think those are correct. So looks like I can accommodate some of what you and Kirk want.
Return to Misc For Sale
