It is currently Thu Apr 18, 2024 1:09 am
[ 23 posts ] |
The purge
If you see it in a pic & I didn't list it, just ask. It's free!
5x Wagon wheels, white, 15x7?, no tires, excellent condition- craven bronco 2 standard black interior rear view mirrors Argent horn button-McPhatmac Hood latch assembly (upper safety hook & lower assembly)- removed from my 74, good working order- EFI Guy Part of an air filter assembly Tail light buckets w/reverse - good condition, need cleaned up (5 total) Sending units Turn signal lenses Tailgate hinges Washer tank w/pump- works Stock jack Lokar shift linkage for 4R70W- EFI Guy Radiator upper mounts & brackets for core support-66crawler Lower steering shaft- stock PS box Antenna Hood prop rod- custom bent Evap can- inside driver's quarter 1" heim misalignment spacers & grade 8 bolts- new- probably have the heims too- from Bloody Knuckle arms or probably Duffs too- Kinder Chrome headlight rings (bed lined, but peeling off easily), buckets & lens retainers- cpldavis Front turn signal buckets Aux tank straps, bracket & skid plate- 66crawler Coil spring upper retainer brackets (from Duff super hoops) Pass seat brackets Ranch hand spare tire body side bracket- McPhatmac 74 Dash switch ID lights, poor condition, don't light up Tailgate supports 302 Bellhousing (might have the clutch arm, not sure) Dashboard- with glove box moved over for roll cage clearance- Toolman Dashboard- cut up pretty bad
Mon Apr 17, 2017 10:21 pm |
Re: The purge
I'll take the Bronco.
Mon Apr 17, 2017 10:35 pm |
Re: The purge
Mon Apr 17, 2017 10:38 pm |
EFI Guy
Re: The purge
Chad, I could use the hood latch assy and 4r70w linkage.
Mon Apr 17, 2017 11:11 pm |
Re: The purge
Tue Apr 18, 2017 6:00 am |
cravenbronco
Re: The purge
Interested in the wagon wheels.
Tue Apr 18, 2017 6:45 am |
Re: The purge
Tue Apr 18, 2017 7:04 am |
Re: The purge
Tue Apr 18, 2017 7:05 am |
Dirtheadz
Re: The purge
PM sent about non listed items!
Tue Apr 18, 2017 7:06 am |
Re: The purge
PM sent back
Tue Apr 18, 2017 7:08 am |
Re: The purge
If the heim parts are still unclaimed I'll take them.
Tue Apr 18, 2017 7:16 am |
Re: The purge
Will bring them with the bench. Will probably bring it up May 5-7. I'll be in touch
Tue Apr 18, 2017 7:21 am |
Re: The purge
In the 5th picture down, is that a passenger quarter "ranch hand" type spare tire attachment? Thingy? Sorry I don't know what they are called or if that's what I think it is...I'll take that if it is??? I would like the plain Horn Button as well :) Pretty PLEASE!!!
Tue Apr 18, 2017 9:07 am |
cpldavis37
Re: The purge
I could use your headlight stuff.
Tue Apr 18, 2017 9:43 am |
Re: The purge
Tue Apr 18, 2017 1:11 pm |
Re: The purge
I can be your Denver drop zone if needed or folks could plan to meet you at one convenient location.
Tue Apr 18, 2017 2:40 pm |
Re: The purge
I could be the Boulder/North Denver drop spot.
Tue Apr 18, 2017 2:47 pm |
Re: The purge
Tue Apr 18, 2017 5:36 pm |
Re: The purge
BTW- shouldn't you be in Moab that weekend?!
Tue Apr 18, 2017 5:38 pm |
Re: The purge
Tue Apr 18, 2017 5:40 pm |
Re: The purge
Added a dashboard with the glove box relocated for roll cage clearance. Also have my 74 dashboard that is pretty hacked up, speaker grill removed, hole cut for radio.
Wed Apr 19, 2017 6:57 am |
TOOLMAN
Re: The purge
Wed Apr 19, 2017 8:10 am |
Re: The purge
Got it, its yours.
Wed Apr 19, 2017 11:48 am |
[ 23 posts ] |
