Assuming they are the typical E7 head, they should fit. Not sure if you would need to change push rods though.mickphatmac wrote:I’m definitely interested!
Do you or anyone else know it they will fit a stock 302 with stock exhaust manifolds?
mickphatmac wrote:Maybe Eck would know?
They are the E7 heads I believe but not sure if they’ll fit the 302 or not. They came off my 351 when I put the GT40 heads on. I’d bet they’d work.
EFI Guy wrote:Keep in mind the 351 heads will have bigger holes for the head bolts than the 302. They make several different styles of kits to address the issue. Everything from special bolts to stepped washers. This is probably the cheapest solution:
https://www.alexsparts.com/head-bolt-re ... -bushings/
Return to Freebies and Trades!
