Booger wrote:Another helpful tool is one to lube the spindle bearings. Used to see them being advertised in 4x4 magazines yrs ago. Built one from a spare wheel bearing retaining nut, a piece of tubing and a piece of flat stock with a grease zerk attached welded to the nut.
Jesus_man wrote:Booger wrote:Another helpful tool is one to lube the spindle bearings. Used to see them being advertised in 4x4 magazines yrs ago. Built one from a spare wheel bearing retaining nut, a piece of tubing and a piece of flat stock with a grease zerk attached welded to the nut.
Post a picture! I use the old method of hand packing, but I have used my dad's bearing greaser a few times and that was nice!
Jesus_man wrote:That's pretty darn cool. Don't even need to remove the bearings. How well does it get that inside bearing?
Jesus_man wrote:Bob - so you're saying it'll do the outer bearing right? I'll be pulling mine apart next week to install new locker, so I'll refresh my memory on how this assembly works.
If you do any trail riding, it's a tool you should carry with you. I have yet to need mine on the trail, but that day will come someday...
