Chassis Part Discount From Ingalls Engineering
Only Approved Vendors or Admins/Mods can post up in this Section and prices MUST be posted. All other specials need to be posted in the open Vendor section.
Postby Crazyone » Fri May 06, 2011 8:33 am
OK guys, here it is. The parts listed below are available for CCB members at a substantial discount from the retail price (over 50% in most cases). Go to http://www.IngallsEng.com , add the parts numbers to the cart that you want then enter the coupon code "CCB" at the bottom of the cart page and hit checkout. The checkout page will show the discount applied. Easy. We don't currently have the original steering arms for the Broncos because of low demand but if there is enough interest, we can look at making a large order for members. I did however include the larger Chevy rod ends for those looking to upgrade. If you are interested in something I have not include, PM me and I see if we can get it added to the list. The discount is good until June 30, 2011. Good luck!
fire fire
IK8194T - Upper BJ Dana 44
IK8195T - Lower BJ Dana 44
IK8447 - Track Bar Bushings
IES2012S - Adjusment Sleeve for Tie Rod
IES2026R - Chevy Tie Rod End
IES2027L - Chevy Tie Rod End
IES2233L - Chevy Tie Rod End
IES2234R - Chevy Tie Rod End
Crazyone
Re: Chassis Part Discount From Ingalls Engineering
Postby Justin » Fri May 06, 2011 9:04 am
This is awesome. Thank you!
Postby akaFrankCastle » Fri May 06, 2011 9:25 am
Sweet! Good timing too. Ive been wanting to yank and rebuild my 44.
Postby Crazyone » Fri May 27, 2011 7:29 am
Bump to top.
Crazyone
Postby Entourage » Thu Apr 26, 2012 8:00 am
Any chance this can be extended into 2012?
Postby Crazyone » Thu Apr 26, 2012 9:02 am
I'll check but I think that would be possible. Let me know before you order so I can confirm that the website has been updated.
Crazyone
Postby Jesus_man » Thu Apr 26, 2012 10:10 am
I added a TRE to my cart and entered the code. Doesn't seem to be working...
Postby Crazyone » Thu Apr 26, 2012 10:27 am
OK, I got it turned back on. The Code is CCB. The discount will be good through the end of May. Let me know if anyone is having any problems. The discount is good for the part numbers listed in the first post.
Crazyone
Postby Entourage » Thu Apr 26, 2012 10:42 am
Sweeeet. Thanks for your help.
There may be a Tech Day for a Tie Rod End build so this may save a lot of money.
Return to CCB Members Only - Vendor Specials
