Need a shuttle from Pueblo to North Denver
Non-Bronco related Wanted section.
Postby phyler » Thu Apr 09, 2020 12:11 pm
If anyone is going down by Pueblo and could pick up a part for me, it would be a huge help. I picked up the ZF adapter from JGZ and need to get it to Erie. Not in a hurry but throwing this out there in case someone is headed that way.
phyler
CCB Admin
Re: Need a shuttle from Pueblo to North Denver
Postby D&D72 » Thu Apr 09, 2020 10:45 pm
If it can find its way to Co springs, I can get it from there.
D&D72
Postby phyler » Fri Apr 10, 2020 9:32 am
D&D72 wrote:If it can find its way to Co springs, I can get it from there.
Thanks! I'm sure this might wait a little until people are moving around a bit. We'll see if anyone else responds.
phyler
CCB Admin
Postby Justin » Fri Apr 10, 2020 8:49 pm
Once I'm not working remotely ill probably go to Pueblo. Might be a month or two.
Postby phyler » Fri Apr 10, 2020 9:05 pm
Justin wrote:Once I'm not working remotely ill probably go to Pueblo. Might be a month or two.
Was going to text you. [emoji16] If it takes long that's fine. I'm just hoarding the parts for my swap as I have the funds.
Sent from my KFKAWI using Tapatalk
phyler
CCB Admin
Postby Justin » Fri Apr 10, 2020 9:43 pm
Sounds good. I'll ping you when it happens
Return to General Wanted
