landshark wrote:I have been cruising craigslist to pick up a used warn 8274 in decent shape. Haven't heard back from anyone there yet but thought I would post up here as well.
My older warn 6200 while working just fine doesn't have power out. Which after testing it this last weekend is a real pain and I think safety issue.
Let me know what you have and what condition.
BroncoCrawler wrote:FYI the 8200 and 8274 originally had 2hp motor until 1998 I believe when it was upgraded to a 4.5 series wound motor. Also there was a rare black 8274 available in 2008 I think with a 6hp motor. The 6hp motor is from the warn HS9500i and can be retroed on any of the old uprights.
Eck wrote:So this thread has me thinking. With my Bronco came an old Warn Belleview. It's only one directional power out and I'm not really sure what condition it is in. Is it worth hooking this beast up or look for something different?
Is there a way to easily test the motor to make sure it's good?
Name plate engraved is 10588470
BroncoCrawler wrote:Those are good winch's and definitely worth doing some trouble shooting. The only issue with them for a recovery situation is the fact it has no ratchet clutch brake, so you have to manually apply the brake via cable in the cab.
To test it just take a pair of jumper cables and attach the positive leads up to battery and winch (the copper stud sticking out of the motor is positive) and then connect the negative cable any place bare steal on the winch. Lastly touch the neg to battery and see what happens.
