ZOSO wrote:I've really been eyeballing that heater but in the 45k btu range.
Glad to see some progress.
Digger wrote:Looking good.
Digger wrote:Are you using an oxygen bottle for an air tank?
I ask because I have two sitting around I was going to do the same thing with.
mickphatmac wrote:1 word... "Multiple Double Cardan Joint!"
Well, you get the idea.
Don't mind me, I'm just on this whole MDCJ kick!
Your rig looks badass, the bottom of it reminds me of the mad Max car with all the explosives and switches and such !
Jesus_man wrote:What's the diameter and length of the bottle? We could figure out capacity roughly. I do like that idea tho. But as you mention - they take up some real estate!
I doubt you would need to turn the 9" enough to affect oiling. I think I ended up shimming mine slightly.
Gunnibronco wrote:I asked my girlfriend if it was weird that I have 2 Broncos. One I'm making unrecognizable, and one I'm looking for 50 year old original parts. I feel its a healthy balance.
Colorado75bronc wrote:With a stock or aerotank and a 9" you should be able to relocate the axle back 3 1/2 - 4"s without an issue. I moved my d60 back 3 1/2.
Justin wrote:The kicker is that if you're going to link it the upper link mounts will interfere with the crossmember under very heavy compression if you go more than about 2" back. You could probably engineer around it, but it'd be a pain.
