TJ's 74 Bronco money pit
Re: TJ's 74 Bronco money pit
Postby Rox Crusher » Thu May 04, 2017 4:39 pm
They could have tested it with an electric fan operating so there would be a load from alternator
Postby cpldavis37 » Wed May 17, 2017 11:53 am
Progress!
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Mon Oct 16, 2017 5:10 pm
Engine installed, Dash restored, glove box built and a few other small things. I am getting close on this one.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Sat Oct 21, 2017 2:10 pm
Half of my order. More to come.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Rox Crusher » Sat Oct 21, 2017 2:25 pm
The engine looks great !
Have you dry fit enough upper intake to see if those valve cover studs will clear ?
Postby cpldavis37 » Sat Oct 21, 2017 3:28 pm
I bought different fasteners for the valve covers I didn't like those ones.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Sat Oct 21, 2017 5:01 pm
Wow, are you planning on paint as well?
Postby cpldavis37 » Sat Oct 21, 2017 5:40 pm
Yes, but it will run first, I hope.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Sun Oct 22, 2017 5:48 pm
Had to build a bench in preparation for the Bronco push. Then I got a new tool box to go with the bench.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Mon Oct 23, 2017 7:24 am
There is something to be said for organized tools! Jobs go much quicker that way!
Postby Viperwolf1 » Mon Oct 23, 2017 8:28 am
Nice bench.
I see you rely on the Rox Crusher gravity method of vise attachment.
Postby cpldavis37 » Mon Oct 23, 2017 10:00 am
Viperwolf1 wrote:Nice bench.
I feel like bolts are so restrictive and really hold back my creative intuition.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Mon Oct 23, 2017 1:17 pm
Jesus_man wrote:There is something to be said for organized tools! Jobs go much quicker that way!
This is so what I’ve been doing wrong all these years.
Postby Jesus_man » Mon Oct 23, 2017 1:47 pm
Guilty here as well!
Postby cpldavis37 » Wed Oct 25, 2017 7:10 pm
More work. It's getting close.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Eck » Wed Oct 25, 2017 7:46 pm
Very clean!! Nice work. Even the lighter holder looks clean!
Postby Jesus_man » Wed Oct 25, 2017 7:49 pm
That looks great in there!! How close to the header is your plug wires on the drivers side? Looks close, but they probably aren't.
Postby cpldavis37 » Wed Oct 25, 2017 8:29 pm
It's not bad. I can make adjustments later. 96 wires are really long so I can route them anyway I want.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Strike2 » Thu Oct 26, 2017 6:17 am
That looks great! nice work, is all the front dressing off a 96 explorer?
Strike2
Postby cpldavis37 » Thu Oct 26, 2017 11:02 am
The serpentine setup comes from a 98 with the exception of the AC delete pulley. That came from my old Mustang setup. I don't really need it, I just thought it looked better with it. The wires are from 96. A 98 has "gt40p" heads and I believe they have some odd bends in them. A 96 has 90* bends at the plug and are better suited for my application and headers.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Fri Nov 03, 2017 7:53 pm
New toys!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Strike2 » Sun Nov 05, 2017 7:40 am
Those are thumbs up parts, interested to see how the sliders install/look as I’m getting ready to see about adding some to my build.
Strike2
Postby cpldavis37 » Thu Nov 09, 2017 3:20 pm
I was going to mock up the cage and got carried away and it's 75% welded. I love it!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Strike2 » Thu Nov 09, 2017 6:19 pm
That cage looks great! On the B pillar are those attachment for seat belts?
Strike2
Postby cpldavis37 » Thu Nov 09, 2017 6:50 pm
Yes
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Dec 14, 2017 9:46 pm
Here is an update. Here we go, Roll Cage welded and bed lined, POR 15 the under side, bed lined the wheel wells, Wiring 90% done, EFI harness and computer done, Explorer 4.0 Radiator and Taurus fan installed and wired, Aux Land Rover pusher fan installed and wired, Dash assembled and installed, new heater core and all new lines. I am leaving some stuff out, but needless to say I have made a ton of progress. My new steering column will be here Saturday and the 23 gal tank should be in before the new year. I might hit my deadline of starting on January 1st.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Dec 14, 2017 9:48 pm
More.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Dec 14, 2017 9:54 pm
More.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Gunnibronco » Thu Dec 14, 2017 9:59 pm
Nice work!
20mm ammo can for a center console?
Postby cpldavis37 » Thu Dec 14, 2017 10:19 pm
Yes sir.
TJ
F. Scott Fitzgerald
cpldavis37
