First Time Bronco Owner - 1969 Bronco
Re: First Time Bronco Owner - 1969 Bronco
Postby pgilbeau » Fri Apr 06, 2018 6:15 pm
Strike2 wrote:sweet upgrades! why a new cage the one you had looked pretty stout?
Changing the cage because I have no need for a family style cage at this point and planning to loose some of the weight. Overall going to be trying to change some weight distribution and lower the CG, I might even be pulling the body lift. We will see what happens before Bronco Safari and then get the rest done later.
pgilbeau
Postby pgilbeau » Tue Apr 10, 2018 8:18 pm
Slow progress happening on the new cage.
pgilbeau
Postby Strike2 » Wed Apr 11, 2018 8:26 am
Nice clean lines I like it!,
For the A-pillar top cross bar are you putting the wiper motor cover back on ?
Strike2
Postby pgilbeau » Wed Apr 11, 2018 12:21 pm
Strike2 wrote:Nice clean lines I like it!,
I haven't decided yet, however the cross bar can be adjusted back some so its probably a possibility that it could fit. I have one at home so probably going to check and see if it will fit.
pgilbeau
Postby pgilbeau » Fri Apr 13, 2018 7:38 pm
Just needs to be fully welded and then I think I am going to get it powder coated.
pgilbeau
Postby D&D72 » Fri Apr 13, 2018 10:46 pm
Looks nice!
D&D72
Postby cravenbronco » Sat Apr 14, 2018 6:04 am
Very nice. I like the way it looks.
cravenbronco
Postby Jesus_man » Sat Apr 14, 2018 3:33 pm
It's got a nice rake to it!
Postby pgilbeau » Tue Apr 17, 2018 12:26 pm
Got a couple pictures of it welded up when we took it out to go to powder coat.
pgilbeau
Postby Dirtheadz » Wed Apr 18, 2018 6:21 am
looks good... classic design & not over done (im a fan a keeping it simple). Its easy to go overboard on tubing and all of a sudden Bronco's looks like an apparatus at a grade school playground.
Dirtheadz
Postby pgilbeau » Tue Apr 24, 2018 12:34 pm
Back from powder coat and installed!
pgilbeau
Postby Eck » Tue Apr 24, 2018 2:56 pm
It’s powder coated 1 color! I was expecting you to match the colors of the Bronco!
Lookin good.
Postby pgilbeau » Tue Apr 24, 2018 2:59 pm
Eck wrote:It’s powder coated 1 color! I was expecting you to match the colors of the Bronco!
Lookin good.
One day it will all be Caribbean turquoise, with any luck I will get some more sheet metal from the Bronco Safari this year.
pgilbeau
Postby cravenbronco » Tue Apr 24, 2018 3:26 pm
Looks good
cravenbronco
Postby pgilbeau » Tue Apr 24, 2018 6:17 pm
New front bumper with my KC Daylighters
pgilbeau
Postby Jesus_man » Tue Apr 24, 2018 6:32 pm
Menacing!
Postby pgilbeau » Fri Apr 27, 2018 8:02 am
Painted up and ready to go with everything installed.
pgilbeau
Postby hockeydad4-22 » Fri Apr 27, 2018 12:57 pm
COOL!
Postby Digger » Fri Apr 27, 2018 3:17 pm
pgilbeau wrote:New front bumper with my KC Daylighters
I like it!
Postby Rox Crusher » Fri Apr 27, 2018 8:24 pm
That thing is screaming “get out the way damnit !”
Previous
