ZOSO's toys
Re: ZOSO's toys
Postby Jesus_man » Tue Jun 13, 2017 7:25 am
Glad you are finally at this point!!
Re: ZOSO's toys
Postby Gunnibronco » Tue Jun 13, 2017 9:32 am
What is the valving? Just curious.
Sent from my SM-J320V using Tapatalk
Re: ZOSO's toys
Postby ZOSO » Tue Jun 13, 2017 1:17 pm
Gunnibronco wrote:What is the valving? Just curious.
345-135D. the D is a digressive piston instead of the standard linear.
Re: ZOSO's toys
Postby ZOSO » Wed Jun 14, 2017 8:30 pm
Lars bars work pretty good with a long enough shock. Not sure 35s will fit. The fronts were rubbing already.
Re: ZOSO's toys
Postby Digger » Wed Jun 14, 2017 9:08 pm
NICE
thumbs up
Re: ZOSO's toys
Postby Jesus_man » Thu Jun 15, 2017 6:09 am
Yeah that looks good!!
Re: ZOSO's toys
Postby landshark » Thu Jun 15, 2017 6:56 am
Looks great. Congrats on getting it up before the trip!
Re: ZOSO's toys
Postby ZOSO » Thu Jun 15, 2017 3:04 pm
Still a list a mile long but it runs. Will be dropping the pan after the swap meet to replace the leaky rear main seal.
Re: ZOSO's toys
Postby EFI Guy » Thu Jun 15, 2017 8:20 pm
ZOSO wrote: Will be dropping the pan after the swap meet to replace the leaky rear main seal.
banghead
EFI Guy
VENDOR
VENDOR
Re: ZOSO's toys
Postby ZOSO » Tue Jul 04, 2017 8:12 am
Hopefully no more pump vapor lock. Only downfall is it has to be an inch lower now.
Re: ZOSO's toys
Postby Kinder » Tue Jul 04, 2017 8:50 am
Nice, what brand of pump did you install?
Re: ZOSO's toys
Postby ZOSO » Tue Jul 04, 2017 10:50 am
It's a northwest metal fab hat with a walbro pump. Holley hydramat pickup. Pulled a walbro inline off and went this route.
Re: ZOSO's toys
Postby Kinder » Tue Jul 04, 2017 6:55 pm
The Holley mat looks cool.
Re: ZOSO's toys
Postby Justin » Tue Jul 04, 2017 8:07 pm
Nice! Which hydramat did you do? I've been eyeballing that.
Re: ZOSO's toys
Postby ZOSO » Wed Jul 05, 2017 7:07 am
Justin wrote:Nice! Which hydramat did you do? I've been eyeballing that.
The 15x3 that fits the bottom of the GSS342bx. All other mats have a pipe thread. In the end the price I spent to adapt all this into the tank I could have bought a retro kit.
Re: ZOSO's toys
Postby ZOSO » Sun Jul 09, 2017 8:00 pm
So I did a thing yesterday. Looks like I'll be gearing it this winter.
Re: ZOSO's toys
Postby Gunnibronco » Sun Jul 09, 2017 8:07 pm
Good to see those rims back in business!
Re: ZOSO's toys
Postby ZOSO » Mon Jul 10, 2017 6:30 am
Gunnibronco wrote:Good to see those rims back in business!
A lot of elbow grease to clean em up but Im happy with them. A great wheel on a bronco. Now if the tires didn't rub at full stuff. May have to trim the flair just a touch. Or pull the rear axle and move it back an inch.
Re: ZOSO's toys
Postby Jesus_man » Mon Jul 10, 2017 8:41 am
That looks great!
Re: ZOSO's toys
Postby B.O.B. » Tue Jul 11, 2017 7:17 pm
Were you able to get them rebalanced so the weights don't hit? I thought they wouldn't but I guess not. Let me know.
B.O.B.
Re: ZOSO's toys
Postby ZOSO » Tue Jul 11, 2017 8:37 pm
B.O.B. wrote:Were you able to get them rebalanced so the weights don't hit? I thought they wouldn't but I guess not. Let me know.
I'm going to take it in tomorrow
Re: ZOSO's toys
Postby ZOSO » Thu Jul 27, 2017 5:40 am
Well now that I have some miles and mountain driving on this thing I will say a couple things. Going back to the explorer clutch fan and ditching the taurus fan. Just cant keep up when working it hard even on high speed. Also lost the relay control and boiled over very quickly.
Next is this thing is a turd below 3k rpm. Not sure if its tune related or not but it barely pulls the passes and has to be floored. It should run a lot better than it does. I know some has to do with the 35's and 4.10's. It also is so sluggish on throttle response and building rpm from idle.
Other than that the trip to ouray was fun but too short.
Re: ZOSO's toys
Postby Jesus_man » Thu Jul 27, 2017 5:47 am
It's hard to compare without riding or driving two broncos side by side, but my 351 seems to have great low-end torque. But down here in IL with oxygen-a-plenty, that could be the difference.
Re: ZOSO's toys
Postby ZOSO » Thu Aug 17, 2017 9:57 am
So a couple weeks ago I had Garry do some more tuning. It is a ton better already. We did our quick trip over mosquito pass and Weston pass. Bronco ran flawlessly except for a heating issue again. Which is due to the clutch on the fan is shot. So now I have to replace that. Also planning to get it and put in alloy axles this winter hopefully.
Re: ZOSO's toys
Postby ZOSO » Fri Apr 06, 2018 6:23 am
Had a few minutes to go check out the 77 since I picked it up. The tub is trashed. A few usable panels like the bed floor and firewall but the majority is rusted beyond easy repair.
Re: ZOSO's toys
Postby Strike2 » Fri Apr 06, 2018 6:42 am
Thanks for sharing the photos!
I think the second best thing to purchasing a project is tearing it apart and seeing what you have. Cant wait to see the build thread on this.
Strike2
Re: ZOSO's toys
Postby Jesus_man » Fri Apr 06, 2018 7:57 am
Poor old girl! Maybe it came from the salt-belt?? I have only see two, maybe three broncos around here. My assumption is they all succumb to the evil that is salt!
Re: ZOSO's toys
Postby ZOSO » Fri Apr 06, 2018 8:06 am
Don't know what kinda shape it was in when the person did all the body work. The guy I bought it from has owned it for 25-30years. It was done prior to him. It has also sat in his backyard since 2000 when he parked it.
Jesus_man wrote:Poor old girl! Maybe it came from the salt-belt?? I have only see two, maybe three broncos around here. My assumption is they all succumb to the evil that is salt!
Re: ZOSO's toys
Postby ZOSO » Sun Apr 15, 2018 5:56 pm
Messed around and got the 77 started. Ran for about 30 seconds till it ran out of gas.
Re: ZOSO's toys
Postby ZOSO » Mon Apr 16, 2018 1:57 pm
Something followed me home.
