It is currently Fri Sep 20, 2024 8:56 pm
Re: Black Smoke Donkey
I'm a fan of green, my youngest wants to paint his Camaro green when we get it done.
Mon Aug 19, 2013 8:42 am |
I quickly mounted one if the seats that Corey grabbed from Jayson (thanks a ton gents) so I could have two passengers on Barbour Fork. It fit nicely, and folds into a good position so I still have a extended bed area. I'll mount the other as soon as I find another footman loop. Dang picture won't load on my phone, I'll get it loaded at home later. Also let my youngest steer for a few minutes on a flat section, got to love diesel torque, no pedals required. http://youtu.be/kC8_iIuAMXE
Mon Aug 19, 2013 10:48 am |
Colorado75bronc
Sweet man, looks like a pro driving that beast
Mon Aug 19, 2013 11:24 am |
Do you plan to have a bench seat as well as the fold up 3rd row seating? That thing is gonna be sweet... would be a perfect hunting vehicle (sans the diesel spooking any animals within a 2 mile radius!)
Mon Aug 19, 2013 12:31 pm |
No bench plan as of yet, if I score a fold & tumble it will go in place of the 2nd row buckets. Geez a 6 passenger bronco isn't enough for you, it has to seat 7!?!?! Actually if it seats 7 it'd be able to carry what my wife's exploder does.
Mon Aug 19, 2013 4:51 pm |
I forgot you were putting buckets in place of the bench. That will look good too-- more of a military look! It will also leave room for a beverage cooler between the seats. http://www.wildhorses4x4.com/product/AR ... MgodU2MAsA
Mon Aug 19, 2013 4:57 pm |
Mon Aug 26, 2013 5:51 pm |
Sweet!
Mon Aug 26, 2013 7:15 pm |
Are you going to shim the gap between the outside of the 2" rectang tube and the inside of the frame ?
I am looking at doing something similar to mine and there is about 1/4" on each side.
Mon Aug 26, 2013 7:19 pm |
Lobobronco
Joined: Wed Sep 29, 2010 9:20 am Posts: 289 Location: Denver, CO
Looks great!
Only...missing the trade mark Kirk hocky pucks/tree savers :)!
Well done!
Matt
_________________ Her name is Lucy...and well...that's who she is!
Mon Aug 26, 2013 7:31 pm |
Mon Aug 26, 2013 8:15 pm |
Mon Aug 26, 2013 8:17 pm |
Mon Aug 26, 2013 8:18 pm |
I think they're bumper nipples.
Mon Aug 26, 2013 8:22 pm |
Kirk - your steel looks pretty stout already, but you might consider putting something inside them to keep them from crushing when you tighten down your thru-bolts. That way you can get the proper sandwich effect on the frame.
How much clearance do you have between the rear of the winch and the grill? You can cut off the horns and get that winch to tuck in tighter. Can you raise it any? With a longer wheel base, you are more likely to nose into the ground on a steep descent. My winch sits on the same plane as the top of my frame. But on my first bronco I had, may have been the same Warn winch bumper and that thing was in the way as it was so low and stuck out so far.
It's easy to be an arm-chair fabricator :-)
Tue Aug 27, 2013 12:49 am |
I don't mind the feedback, I seek it, especially when it's good. I've not considered sleeving the tube, I'll look into it as I also want to sleeve the trans mount. I did consider mounting it higher, but it will stick out the same amount. I left less than an inch between it and the grill and with my body lift I'm getting more flexing than before so I need the space. If I move it higher I could cut the tubes at an angle, I'll take some measurements and see how that would affect my approach / departure angles.
Tue Aug 27, 2013 10:05 pm |
Black Smoke Donkey
Four buckets! I also channeled my innermost Phil yesterday and reused a cable end on my winch power connection. The old cable had seen better days but had a desirable end, so I cut off the cable and drilled the end out, filled the little cup area with solder, heated it up and pressed in the new 1 ga cable.
Fri Aug 30, 2013 8:06 am |
You may have already covered this but how are you doing the rear doors?
Fri Aug 30, 2013 8:16 am |
I don't know if doors are in the plan or not but doors without window frames would be really cool looking on that rig
Fri Aug 30, 2013 11:35 am |
Black Smoke Donkey
Yes, doors will be built for the back openings, section and hinged suicide style. Both front & rear doors will have removable frames.
Fri Aug 30, 2013 2:14 pm |
Loaded up the Donkey Cart with around 750lbs and tugged it all over the metro area today. Have I said I love my diesel yet?
Thu Sep 05, 2013 1:09 pm |
JGZ
I saw you on C-470 near Kipling.You seemed to have a crap eatin grin on.Awesome
Thu Sep 05, 2013 1:36 pm |
Thu Sep 05, 2013 1:55 pm |
Combined wheelbase = 478 inches. :-)
Thu Sep 05, 2013 2:46 pm |
Geologist
Kinder, amazing job!! Looks great and love that trailer!
_________________ 1966 Bronco, rebuilt 302, Twin shift Dana 20, T19, 3.5 suspension lift, 2 inch body, 35x12.50 tires
Thu Sep 05, 2013 5:01 pm |
kbank6
So when are you going to mass producing the trailers? I'd like to get on that list...
Thu Sep 05, 2013 7:55 pm |
That's an expedition/overland rig if I've ever seen! I love it!
Fri Sep 06, 2013 1:20 am |
Black Smoke Donkey
Geo & kbank, check out the link, it's the build thread on my trailer. It was a project of "firsts" for me; welding, cutting, sheet metal work, suspension, etc. There are still a few loose ends on the trailer to finish, but it has been yanked all over mountains and performed well. viewtopic.php?f=3&t=67Just wait until I set the camper on and then things are going to get with the overland / expo theme.
Fri Sep 06, 2013 8:25 am |
Geologist
Fri Sep 06, 2013 10:02 am |
Fri Sep 06, 2013 5:10 pm |
