Rox Crusher's 77 sport
Re: Rox Crusher's 77 sport
Postby landshark » Fri May 27, 2016 3:33 pm
Need be would like to see how the install goes
Postby Rox Crusher » Fri May 27, 2016 9:39 pm
landshark wrote:Need be would like to see how the install goes
This is a decent write up. But I'm not going to route the hoses through the fresh air intake like he did. I'm going to look at what Dana at BH does.
http://classicbroncos.com/forums/showth ... 513&page=2
Postby Rox Crusher » Wed Jun 08, 2016 8:24 am
Speaking of my seats..........some Bronco guru / private investigator just texted me these.
Postby BroncoRaider » Wed Jun 08, 2016 9:31 am
Those look fantastic!
BroncoRaider
Postby Dirtheadz » Wed Jun 08, 2016 12:23 pm
sexy!
Dirtheadz
Postby D&D72 » Wed Jun 08, 2016 4:37 pm
Nice!
D&D72
Postby Viperwolf1 » Wed Jun 08, 2016 5:50 pm
Looks like you found the spot where the '70s and the '80s meet.
Postby TOOLMAN » Thu Jun 09, 2016 6:00 am
Those look pretty sharp... thumbs up
TOOLMAN
Postby Digger » Thu Jun 09, 2016 7:30 am
Rox Crusher wrote:Speaking of my seats..........some Bronco guru / private investigator just texted me these.
Those look like the same seats my '93 Ranger had. Cool upholstery job.
Postby Rox Crusher » Wed Jun 22, 2016 5:23 pm
Thank you 427wrangler for sending me the wiper switch !
It will work perfectly for the passenger ejection system I installed (or is it just for turning the overdrive off ?)
Postby Gunnibronco » Wed Jun 22, 2016 5:40 pm
Very cool!
Postby landshark » Thu Jun 23, 2016 6:46 am
have you started the AC install?
Postby Rox Crusher » Thu Jun 23, 2016 9:42 am
landshark wrote:have you started the AC install?
nope, got distracted with my silly job
haven't even picked it up from BH yet
Postby Rox Crusher » Sun Jun 26, 2016 8:30 pm
Spencer named our Bronco "Honkey" today
Something went haywire with the horn so it randomly honks when driving
Postby Justin » Sun Jun 26, 2016 9:10 pm
That's hysterical. It's exactly what Alex would have done, completely not understanding the other meanings.
Postby BroncoRaider » Sun Jun 26, 2016 10:30 pm
BroncoRaider
Postby landshark » Mon Jun 27, 2016 3:42 pm
wire came loose behind the horn button and hitting metal randomly closing the connection?
Postby Rox Crusher » Mon Jun 27, 2016 5:10 pm
landshark wrote:wire came loose behind the horn button and hitting metal randomly closing the connection?
Yup
Happened once before, gotta solder it back on again
Postby landshark » Mon Jun 27, 2016 7:37 pm
Happened to be driving down federal a while ago, want even cinco de mayo
Postby Rox Crusher » Sun Sep 04, 2016 3:57 pm
I haven't had an opportunity to do much on Old Honkey lately.
2 or 3 weeks ago I ran it up to Garry's to do an initial tune and eliminate some lean codes I was getting. We adjusted the fuel pressure regulator up a bit as it it would drop from 65 down to 55 or so under WOT. Then Garry did his magic on the computer and no more lean codes. Having said that, I went a bit far on the FPR adjustment as it was up to 73 psi at idle but I wasn't really concerned.
About a week later I was running errands and lost fuel pressure. Dropped from 73 down to a max of 25 (if I cycle the key a few times without running engine). found out that motor needs min of 16 psi to idle.
Turns out the hose between the pump and the pick up burst right at the clamp.
I'm almost wondering if it already had a small crack and a small leak which is what was making my 5.0 run crappy when it was in there and it finished itself off with the extra pressure required for the new system.
Anyway, yet another day sniffing gas fumes to get it running.
Postby ZOSO » Sun Sep 04, 2016 4:23 pm
If it's too much I have a set of 24lb injectors i'll let go of cheap. Just have to get with Garry and see if we can get the info for them. They are some odd ford injectors.
Postby Rox Crusher » Sat Jan 14, 2017 12:56 pm
The 351 was running hot since I put it in, it would get as hot as 225 on a hot day. I thought it was just the nature of the beast and needed to upgrade cooling system.
After converting to 94 Explorer radiator it was too cool, reaching a max of 180 or so.
Replaced the thermostat and it now runs at 192 as it should.
Will be interesting to see what it does this summer.
Postby Rox Crusher » Sun Apr 15, 2018 7:13 am
Phil and I have been working away at the task list to get ready for Baja Bronco Adventure.
Postby Kinder » Sun Apr 15, 2018 8:02 am
That case looks good, same as Scott’s? I think we should start calling the nose up rake the Baja Bronco Squat!
Postby ScottBarnes » Mon Apr 16, 2018 5:22 pm
Kinder wrote:That case looks good, same as Scott’s? I think we should start calling the nose up rake the Baja Bronco Squat!
No Mo Squat on mine! ;-)
Go Hard or Go Home
ScottBarnes
Postby Jesus_man » Tue Apr 17, 2018 11:48 am
Fixed with what style add a leaf?
Postby Viperwolf1 » Tue Apr 17, 2018 1:17 pm
A soft top will get rid of that squat.
Postby TOOLMAN » Wed Apr 18, 2018 6:17 am
I'm liking those wheels! thumbs up
TOOLMAN
Postby Gnsteam » Sat Aug 11, 2018 7:40 am
Hi Jeff,
I had the opportunity to read through your 77 Sport thread this morning. What a great looking rig. I really like the upgrades you have made, while keeping the stock look. That is the way I like em. I see that your hard top changed colors. Did you do a repaint and decide to go with the white? Either way it still look great white or blue. Somewhere on this forum, I seen a photo of a hidden winch upgrade your working on. Will you be adding information and build pic's to this thread? This is an upgrade I would like to do at some point, so interested in seeing how it all works out for you.
Once again, Great Bronco! :beer:
Fred
Gnsteam
Postby Rox Crusher » Sat Aug 11, 2018 4:32 pm
Hello Fred,
The Bronco was repainted by a previous owner and the top had some rusty spots. I found a really nice top that had been reconditioned and repainted white which happened to match the painted stripes on mine perfectly. So I bought the white top and traded the blue one off.
When I win the lottery and get the body work and paint done I plan to go back to a color matched top.
I will be adding the hidden winch upgrade to the thread when I get back to finishing it up.
Jeff
