TJ's 74 Bronco money pit
Re: TJ's 74 Bronco money pit
Postby Kinder » Fri Jun 21, 2019 2:26 pm
It’s been a long road, very happy you have it to a level you like it. I think it looks great.
Postby cpldavis37 » Mon Nov 18, 2019 4:26 pm
I installed an on board air setup. It cost about 250 in total, so half the price of the ARB compressor I was considering.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Mon Feb 24, 2020 1:00 am
I ordered it in July and I finally got it. It was worth the wait. Thank you BC Broncos.
The top goes together easy enough, but getting the snaps on is a son of a gun.
TJ
F. Scott Fitzgerald
cpldavis37
Postby mickphatmac » Mon Feb 24, 2020 9:43 am
I really like the Look of those!
Images: 14
Postby landshark » Mon Feb 24, 2020 10:51 am
cpldavis37 wrote:I ordered it in July and I finally got it. It was worth the wait. Thank you BC Broncos.
Its a great top - it gets easier to snap in the warmer weather. I had a person add pull tabs to the bottom 4 snaps on each side to help get those ones snapped. Also you will want to buy a button replacement kit because the snaps will break over time. The kits can be found on amazon or locally... (example of one)
https://www.amazon.com/Fasnap-Premium-S ... B00JI7YZDO
I want to get rid of the snaps and find an alternative eventually...
Postby cpldavis37 » Mon Feb 24, 2020 11:16 am
Thanks for the info, I'll order some.
TJ
F. Scott Fitzgerald
cpldavis37
Postby landshark » Mon Feb 24, 2020 11:53 am
I also found - and it will depend on your top and the fit - that using a door panel clip removal tool is nice as it makes the snaps last longer and pops them right off. I happened to have one from other projects and found it useful :)
https://www.amazon.com/Cal-Hawk-Door-Pa ... 336&sr=8-1
Postby cpldavis37 » Mon Feb 24, 2020 2:07 pm
Good idea!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Mon Feb 24, 2020 7:20 pm
NASCAR Mike, does he still go by that nick?, had some different style canvas attachment snaps on his locally made 1/2 cab soft top, something like this. They seemed to work well in the cold and looked like they’d hold up a bit better over time.
Postby Jesus_man » Tue Feb 25, 2020 8:14 am
Top looks great!!
Having had tonneau covers on all my trucks, I knew to avoid snaps and velcro. There was two options that would work here assuming that there is some sort of channel mounted to the bedsides? This cover had an extruded aluminum channel that mounted to the bed. Then the cover had an extruded plastic hook attached to the fabric. This was great as there were no snaps and no velcro.
Here is the basic concept for this tonneau. It would have to be rolled 90 with the channel facing down to work for a bronco top.
Postby landshark » Tue Feb 25, 2020 9:24 am
Kinder wrote:NASCAR Mike, does he still go by that nick?, had some different style canvas attachment snaps on his locally made 1/2 cab soft top, something like this. They seemed to work well in the cold and looked like they’d hold up a bit better over time.
Ya i have been looking at those. I will ask him thanks!
Postby landshark » Tue Feb 25, 2020 9:27 am
Jesus_man wrote:Top looks great!!
I dont think there would be anyway to make that work on the sides and back of the BC top. Once the sides and back are on they are comparable to a hardtop as there is almost no movement aka flapping that you get in normal soft tops because they fit well and taught. I would think it would be nearly impossible to get the side lip into a channel once you have the top in place. But I could be wrong!
Postby Jesus_man » Tue Feb 25, 2020 9:36 am
What tightens the fabric? Perhaps I don't understand the install. If my assumptions are correct, this style of fastening wouldn't be any different than the snaps.
Postby cpldavis37 » Fri Feb 28, 2020 1:57 pm
It is tight to begin with you pull it and snap it. Once the top is installed it has 2 turnbuckles on the rear bar that you can tighten when needed.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Wed Mar 17, 2021 1:04 pm
I snapped a front axle shaft this weekend. On a good note it was a stock shaft and I have been wanting an upgrade for years. I ordered the TBP "Trail Terminator" front axle shafts. The website advertises 60% stronger than stock. We shall see.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Mar 18, 2021 3:02 pm
Oops I broke both sides at one time. lol
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Fri Mar 19, 2021 4:49 pm
Um, that may mean that you need to ease up on the skinny pedal!
Postby cpldavis37 » Fri Mar 19, 2021 5:27 pm
That's just so difficult.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Mon Mar 22, 2021 7:22 am
LOL! It is at times, but I know my wallet dictates how much throttle is applied after a few sets of u-joints and shafts!
Previous
