Project Downward Spiral
Re: Project Downward Spiral
Postby phyler » Sat Sep 24, 2022 5:31 pm
Well, it's been a year (almost) and I've done nothing but drive it. Got it to Super Celebration and on the way back developed a pretty rough vibration at any speed over 50mph. That made for a longer than desired drive back (3+ hours).
Got under to measure the pinion angle for good measure since I never did it after replacing the suspension. When I pulled the drive shaft to measure up against the yolk, one of the u-joint caps just fell off. Needles completely gone and the cap was cracked. Guess I found the source. [emoji16]
Pinion angle is currently at 10 degrees. Will probably buy some of the 6 degree shims to get it between 4 and 6 degrees.
The downward spiral here is that I will probably go ahead and start the transmission swap as I know I will need to modify the drive shafts. I have 95% of the parts for the ZF swap so, why not? [emoji1787]
So, who has a good transmission jack that I can borrow?
phyler
CCB Admin
Postby Eck » Sat Sep 24, 2022 5:45 pm
That’s good you found the issue and I agree with your solution. The angle will only get more extreme with the ZF5 and shorter rear shaft. I was blowing through u joints too until I added shims to solve the angles. Haven’t had an issue since adding the shims.
I do not have a trans Jack but will take the opportunity to take a dig at the HF one. It sucks.
Postby phyler » Sat Sep 24, 2022 8:24 pm
Eck wrote:That’s good you found the issue and I agree with your solution. The angle will only get more extreme with the ZF5 and shorter rear shaft. I was blowing through u joints too until I added shims to solve the angles. Haven’t had an issue since adding the shims.
Maybe I'll wait on the shims then and see if I just want to replace the perches and set the angle correctly.
In regards to the HF jack, are you taking about the crappy $50 scissor style one? Or the hydraulic one?
It's more about getting the NP435 out with the transfer case attached. It's just a lot of weight that is super awkward.
phyler
CCB Admin
Postby Eck » Sat Sep 24, 2022 8:36 pm
The hydraulic one. It’s more about the stability of the platform. If you end up using that one, I’d definitely figure out a way to create a more secure base to drop the trans onto.
I’d maybe suggest figuring out the expected perch location with weight. I tried to rotate and do mine without the weight on the axle and was off enough to have to add the shims.
Postby Kinder » Sun Oct 16, 2022 8:16 pm
Still need a trans jack? I have the larger hydraulic jack and you’re welcome to borrow it. I’d recommend taking the D20 out first, then drop the trans. It’s a bit unwieldy to drop them together.
Postby phyler » Sun Oct 16, 2022 8:21 pm
Kinder wrote:Still need a trans jack? I have the larger hydraulic jack and you’re welcome to borrow it. I’d recommend taking the D20 out first, then drop the trans. It’s a bit unwieldy to drop them together.
Yes! Happy to coordinate with you.
I've done the np435 with the 20 attached more times than I'd like to count. Will definitely do them separately this time.
phyler
CCB Admin
Postby phyler » Sun Nov 13, 2022 4:07 pm
Just checking, on the ZF swap, is there anything besides the adapter that is vendor specific? I feel like in the past there was a part from BC Broncos that people recommended but can't remember what it was. I have the following parts:
Transmission
Adaptor
Need to purchase:
Twin stick
Master/Slave for a 97 F250 (looking at this:https://www.rockauto.com/en/moreinfo.php?pk=6810684&cc=1125144&pt=10290&jsn=997&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbh%2BYrdIIoJ2QvjAcW39YRTU02C77No248W9oPPOPBa0%2ByMrUiaYjGVdwQceOjej2TuRe8f1GOf47sMaJHuB2tqvqdSsnDMzZS%2BPFgkvTqkWLgOZVO813ylSDJPs19l39n19W6OCpq%2FbelY7ko7Z9oiyj0yJwuY3FqAMPP%2FASLChZomSCN%2BoJnGoGuFe%2FRQbUIkDliKLn1wfiQD1nOS4T27ZE%2BL8rzaMliyJdHHoOADvyvmtvB61xC0G10JSwF2HbsoP0GvDWY2pfHKsQ3d9A%2BTnwzsFbY9zRzGrdRpJmEYXg&jsn=997&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbh%2BYrdIIoJ2QvjAcW39YRTU02C77No248W9oPPOPBa0%2ByMrUiaYjGVdwQceOjej2TuRe8f1GOf47sMaJHuB2tqvqdSsnDMzZS%2BPFgkvTqkWLgOZVO813ylSDJPs19l39n19W6OCpq%2FbelY7ko7Z9oiyj0yJwuY3FqAMPP%2FASLChZomSCN%2BoJnGoGuFe%2FRQbUIkDliKLn1wfiQD1nOS4T27ZE%2BL8rzaMliyJdHHoOADvyvmtvB61xC0G10JSwF2HbsoP0GvDWY2pfHKsQ3d9A%2BTnwzsFbY9zRzGrdRpJmEYXg&jsn=997&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbh%2BYrdIIoJ2QvjAcW39YRTU02C77No248W9oPPOPBa0%2ByMrUiaYjGVdwQceOjej2TuRe8f1GOf47sMaJHuB2tqvqdSsnDMzZS%2BPFgkvTqkWLgOZVO813ylSDJPs19l39n19W6OCpq%2FbelY7ko7Z9oiyj0yJwuY3FqAMPP%2FASLChZomSCN%2BoJnGoGuFe%2FRQbUIkDliKLn1wfiQD1nOS4T27ZE%2BL8rzaMliyJdHHoOADvyvmtvB61xC0G10JSwF2HbsoP0GvDWY2pfHKsQ3d9A%2BTnwzsFbY9zRzGrdRpJmEYXg )
I know I need to fab up the piece for the clutch pedal to the master as well as I will need to fab the cross-member. After it is in, I'll need new drive shafts.
While it is all out, I will be re-sealing the Dana 20 (it works great, just has some minor leaks and why not, this is the downward spiral after all).
What else am I forgetting?
phyler
CCB Admin
Postby Eck » Sun Nov 13, 2022 4:34 pm
The BC part is the hose for the master to slave cylinder.
Postby Gunnibronco » Sun Nov 13, 2022 4:57 pm
phyler wrote:Just checking, on the ZF swap, is there anything besides the adapter that is vendor specific? I feel like in the past there was a part from BC Broncos that people recommended but can't remember what it was. I have the following parts:
Transmission
Adaptor
Need to purchase:
Twin stick
You are running a body lift? Without it, you'll really struggle to get the ZF to fit. Also expect to modify the shifter to clear the dash board. The second post on the link below seems to be the easiest way to move the shifter to a better location.
https://classicbroncos.com/forums/threa ... 977/page-2
Buy the best master and slave you can. You don't need to bother buying a kit with the line from the master to the slave cylinder. It won't fit and you'll need the soft stainless line BC offers. I built an adjustable pedal stop into my clutch pedal. I've read that you can blow the seals out of the slave cylinder if your pedal travels too far. I can't confirm this and I'm not sure how real the problem is.
But pulling the trans to replace the slave cylinder is something you'll obviously want to avoid.
Postby phyler » Sun Nov 13, 2022 5:55 pm
Transmission
Adaptor
Need to purchase:
Twin stick
Thanks. I am running a body lift.
Ok, I'll look for the line on BC's site. I didn't see it last time I looked but that site isn't the best.
I'll look for the master and slave as separate parts vs the kit then.
phyler
CCB Admin
Postby Gunnibronco » Sun Nov 13, 2022 8:38 pm
Yeah it's pretty bad I just checked it out. I was able to search "zf hose" and find more than using their product catagories. You may be able to have a local hydraulic shop make the line instead of using BCB. They aren't my favorite vendor.
Postby phyler » Wed Nov 23, 2022 7:42 pm
Ordered on Sunday night. Both BC and rock auto showed today. Jb fab twin stick should be here on Friday. Guess I need to make this happen. Image
phyler
CCB Admin
Postby phyler » Sat Mar 04, 2023 6:12 pm
Well, the old NP435 is out.
Now I need to get the Dana 20 cleaned up and resealed. How hard is it to do?
Anyone need an NP435 with adapter?
phyler
CCB Admin
Postby Kinder » Mon Mar 06, 2023 2:23 pm
Sealing the D20 is easy, grab a couple of output seals, front & rear, and a PTO cover seal and your done. Check the yokes for wear where the seals sit, if they are bad you may want to get replacements or they’ll continue to leak.
Postby phyler » Mon Mar 06, 2023 5:55 pm
Kinder wrote:Sealing the D20 is easy, grab a couple of output seals, front & rear, and a PTO cover seal and your done. Check the yokes for wear where the seals sit, if they are bad you may want to get replacements or they’ll continue to leak.
Sounds easy enough. Just need to clean this sucker off.
Sent from my KFKAWI using Tapatalk
phyler
CCB Admin
Postby phyler » Sun Sep 17, 2023 7:21 pm
Felt like I should do an update. The ZF project is taking forever due to my travel schedule. We got the transmission in back on Memorial Day weekend. Got the cross member finished in August. This weekend, I got the master cylinder in and modified the clutch pedal.
Sadly, it appears the slave is bad. I know @Eck ran in to this. Have been trying to bleed it for hours and no change in pressure. So, transmission gets to come back or. [emoji2959]
I had bought Luk for both the master and slave thinking it might be better. Evidently, that doesn't matter as pretty much all of them have the same reviews.
I'm back on the road for the next two weekends so it will have to wait again. Might try and get the measurements for the driveshafts so I can get those going. Maybe if they come in, I can do another wrench day to try and get it all going in one shot. ImageImage
phyler
CCB Admin
Postby Justin » Sun Sep 17, 2023 8:14 pm
If it makes feel any better you're still going faster than I would. I spent the extra for a Sachs master and slave because of Eck's experience and had no issues with bleeding.
Postby phyler » Sun Sep 17, 2023 8:37 pm
Justin wrote:If it makes feel any better you're still going faster than I would. I spent the extra for a Sachs master and slave because of Eck's experience and had no issues with bleeding.
Good to know on the Sachs. I really thought Luk would make a decent setup.
I hope to have it done before the end of the year. [emoji1787]
phyler
CCB Admin
Postby phyler » Sun Sep 17, 2023 8:48 pm
Looking online, it doesn't show that the Sachs fits. My ZF is out of a 97 F250. It's the 47 and not the 42 version.
Wonder what is different between them.
phyler
CCB Admin
Postby Justin » Sun Sep 17, 2023 10:03 pm
No idea, but mine is a 42
Postby phyler » Mon Sep 18, 2023 7:24 am
What's more interesting is the Luk part is the same for 96 and 97. Guessing that 97 is just a bit of an odd ball as it was the end of the line for that transmission in the trucks. Probably no difference. Rock Auto has the Sachs for half the price of the local stores. Might have to try it.
phyler
CCB Admin
Previous
