TJ's 74 Bronco money pit
Re: New Bronco Owner Yesssssssssssssss
Postby cpldavis37 » Sun Apr 08, 2012 8:36 pm
That will put a stop to this project(no pun intended). And I just painted them. Auto Zone wins again!
TJ
F. Scott Fitzgerald
cpldavis37
Re: TJ's 74 Bronco money pit
Postby Viperwolf1 » Sun Apr 08, 2012 8:49 pm
Ouch. Those cast iron drums are kind of fragile.
Postby cpldavis37 » Wed Apr 11, 2012 8:11 pm
Finished the brake job all in drums and new steel braided extended lines. Now I remember why I hate drum brakes. I will do a disc conversion at some point but for now I just wanted to get it rolling.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Mon Apr 16, 2012 5:10 pm
Bronco's first time in the dirt. The twin stick works great. Thanks again Viper.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Tue Sep 10, 2013 9:03 am
I am starting the floors tomorrow. I will take some pictures. I am sure it will be an adventure considering I have never welded before. :Welding: I have a couple of guys from work coming to help, should be fun.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Tue Sep 10, 2013 9:05 am
Good luck! If you run into trouble, one of us should be able to swing by and help. I probably could on my way home from work tomorrow.
Postby cpldavis37 » Tue Sep 10, 2013 12:45 pm
Thanks I will let you know.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Tue Sep 10, 2013 11:11 pm
Cut your teeth on the passenger side, it's easier. Also remember that electric, fuel and brake lines run along the drivers side frame rail, take care when cutting that side out.
Postby cpldavis37 » Wed Sep 11, 2013 5:40 pm
Well as usual stuff always takes longer than expected. The cross brace was snapped in half , so I had to fix that. I am 60% done with the drivers side. Had to goto work.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Wed Sep 11, 2013 6:48 pm
Thanks for the advise Kinder, I didn't read the post until after I started. If that was the hard side at least its almost done.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Wed Sep 18, 2013 7:53 pm
Welding is harder than it looks.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Wed Sep 18, 2013 8:20 pm
Want help or a lesson?
Postby cpldavis37 » Thu Sep 19, 2013 12:53 am
I am almost done l. I should have asked for help instead of watching youtube lol. I was having trouble getting the heat and wire right. It really looked bad until I ground it down. I guess you live and learn.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Thu Sep 19, 2013 5:52 am
You're learning the same way I did. Glad to hear it's coming along!
Postby Eck » Thu Sep 19, 2013 6:47 am
:worthless:
Let's see some pics of the progress! The only real way to learn is to just do it. I learned the same way last year although Justin did give me a crash course. After I was about 98% done with all of my body work, he and I went to 2 MIG classes. Maybe should've gone to those earlier!
Postby Peter Werlin » Thu Sep 19, 2013 4:18 pm
Hi members, I just joined too. I guess I'm not smart enough to figure out how to post pictures but mine is a 67 that my dad bought new and I bought in 1978 when I was 15! It looked good through high school and college, then it was bad! Should have gone to jail for Bronco neglect! After 25 years of starts and stops on the restoration it's almost done! It runs! Hope to drive it out of the mountains to the October lunch. I look forward to meeting people and helping others. I'm not very skilled, but can teach patience and perseverance!
Peter
Peter Werlin
Postby Jesus_man » Fri Sep 20, 2013 12:28 am
Peter - you need to start your own build thread so we can see what you've been up to.
I prefer to host my pictures on a site called www.photobucket.com and you can copy/paste code from there to here to display pictures.
Postby cpldavis37 » Wed Feb 05, 2014 10:43 pm
I just bought 4.56 gears, Aussie locker, a master rebuild kit, and outer brake lines for the 76 disc brake front end that I bought a while back. No gear swap would be complete without the rear goodies, so I got 4.56 gears a 31 spline grizzley locker and 31 spline alloy axles and a master rebuild kit.
I hope my wife doesn't look at the bank account in the morning. If she does I don't think I will live long enough to install this stuff.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Eck » Wed Feb 05, 2014 11:08 pm
cpldavis37 wrote:I just bought 4.56 gears, Aussie locker, a master rebuild kit, and outer brake lines for the 76 disc brake front end that I bought a while back. No gear swap would be complete without the rear goodies, so I got 4.56 gears a 31 spline grizzley locker and 31 spline alloy axles and a master rebuild kit.
Jealous! Take pics and notes do the install and build thread. I'd love to learn from your progress
Postby cpldavis37 » Wed Feb 05, 2014 11:13 pm
I will do my best. Kinder said he would help out. When I get ready to install everything anyone can come over and learn. This will all be a first for me.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Wed Feb 05, 2014 11:37 pm
We'll be doing my gears soon, possibly on the 15th. You're welcome to come over and hang out.
Postby cpldavis37 » Wed Feb 05, 2014 11:47 pm
I think I am working I will check tomorrow when I go in. Pm me your address . I'll be over if I can.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Feb 06, 2014 3:17 am
I also bought everything I need for the ruffstuff knuckle over conversion. Kinder offered to help build the set up. This project would have died a long time ago without Viper, Kinder and this club. Thanks everyone.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Thu Feb 06, 2014 10:13 am
Gearing / axle upgrades seem to be the thing this year, 9's are straight forward and easily done with the axle in or out of the vehicle. D44's are not as fun loving and if we can do them while the axle is out of the vehicle it makes life better.
Postby cpldavis37 » Thu Feb 06, 2014 3:17 pm
Then I am in luck. The front is sitting on the garage floor.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Tue Feb 11, 2014 1:39 pm
It's like Christmas!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Tue Feb 11, 2014 2:08 pm
Sweet! That looks like a pile of fun.
Postby cpldavis37 » Fri Feb 14, 2014 7:15 am
Another piece to the axle puzzle.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Fri Feb 14, 2014 8:00 am
I love my Aussie locker, front right?
Postby cpldavis37 » Fri Feb 14, 2014 11:26 am
Yes. I went with the Aussie front and a Yukon Grizzly rear.
TJ
F. Scott Fitzgerald
cpldavis37
