It is currently Fri Jun 28, 2024 9:36 am
Re: Badlands 66
Havent updated this lately. I've got some more done. I have the fuel lines 95% done. Still have to mount them. They run along the top of the frame rail. When they come into the engine bay they are in the fender. Phil came over. This is how things looked when he left. we dont think this D20 has ever been apart. We had to fight to get it apart.. And it shows too. Many worn bearings. So now I got to get new bearings. Radiator mock up. The bottom of the core support is tweeked. It pushes the radiator towards the fan by almost an inch. got the fuel lines ran to the TB. Heat wrapped the supply line. Hooked up and tested the BC throttle cable. Mounted the top side of the BC kickdown cable.
Wed Mar 14, 2012 7:36 pm |
Re: Badlands 66
Looks great guys - amazing progress in a very short time.
Wed Mar 14, 2012 7:41 pm |
Re: Badlands 66
Wed Mar 14, 2012 7:48 pm |
Re: Badlands 66
Nice work! I like how you ran the fuel lines! Should keep them cool for as long as possible.
The small stuff always takes the longest! Keep at it!
Thu Mar 15, 2012 8:05 am |
Badlands
Joined: Mon Apr 25, 2011 9:02 pm Posts: 340 Location: Littleton
Re: Badlands 66
Nice work Rob and others! More progress has been made in 3 weeks than was made in 3 months before. Thanks!!!
Thu Mar 15, 2012 11:05 am |
Re: Badlands 66
not to hijack but running the lines on top of the frame, i assume to keep them away from the engine/tranny/tc?
Sun Mar 18, 2012 9:08 pm |
Re: Badlands 66
landshark your thinking right. Away from the heat to minimize the chance for vapor lock.
Mon Mar 19, 2012 4:38 am |
Re: Badlands 66
Not much progress this past weekend. I had to go play a little. Got the t-case All cleaned up and ready for the rebuild. The parts showed up today.
Tue Mar 20, 2012 8:26 pm |
Re: Badlands 66
got my Y steering from a guy off CB.com, have to clean em up and get them painted...
Tue Mar 20, 2012 9:06 pm |
airbur
Re: Badlands 66
Tue Mar 20, 2012 9:20 pm |
Re: Badlands 66
Tue Mar 20, 2012 9:49 pm |
Re: Badlands 66
Tue Mar 20, 2012 9:59 pm |
Re: Badlands 66
Got the tcase painted. Got the ecu in and the wire harness in place. Will hook up the connections tomorrow. Got the bottom of the core support bent so the radiator sits straighter now.
Wed Mar 21, 2012 9:27 pm |
Re: Badlands 66
Fri Mar 23, 2012 9:14 pm |
D&D72
Re: Badlands 66
Put some clear coat over that viper built signature!
Fri Mar 23, 2012 10:35 pm |
Badlands
Re: Badlands 66
Sat Mar 24, 2012 10:05 am |
Badlands 66
Phil- you need to carry your stencil with you all all times! You never know when you need to tag something VIPER BUILT.
Sat Mar 24, 2012 11:45 am |
Re: Badlands 66
Didnt get around to much today. Went and got some more bolts. Need to get some cotter pins for the t case shifter. Installed the rear driveshaft. My thumb still really hurts from smashin it pretty bad friday night. Hope to make some more progress tomorrow.
Sat Mar 24, 2012 8:40 pm |
Re: Badlands 66
Mon Mar 26, 2012 8:08 am |
Re: Badlands 66
Slow slow slow. Got the crossmember back in and bolted up. Lower radiator mounts welded in. Tcase shifter in. Floor patched. Seat back in. Steering column finished bolted in. Trans linkage in.
Thu Mar 29, 2012 6:22 am |
Badlands
Re: Badlands 66
Thu Mar 29, 2012 7:36 am |
Re: Badlands 66
Big thanks to booger and Badlands. We were able to fire it up and get some time on the cam. Has about 15 minutes runtime.
Sat Apr 07, 2012 3:41 pm |
Badlands
Re: Badlands 66
The beast is alive!!
Sat Apr 07, 2012 5:03 pm |
Re: Badlands 66
Sat Apr 07, 2012 9:13 pm |
Re: Badlands 66
It sounds soooo good too. Nice work ZOSO!
Sat Apr 07, 2012 9:45 pm |
Re: Badlands 66
Well I got it to idle some this morning. Also put another 5 minutes on the cam. Once it idled I moved it forward and back a foot in gear. So the trans works atleast that far. Now to figure out why it's not charging.
Sun Apr 08, 2012 9:26 am |
Re: Badlands 66
So it developed a massive vacuum leak somewhere. Wont idle stable and runs really rich. So time to pull the throttle body and see where its at.
Mon Apr 09, 2012 9:00 am |
Re: Badlands 66
Redid the tb gaskets today. Disconnected all vacuum hoses other than the map sensor. still only seeing 5in of vacuum. going to do a compression test and leak down before the intake comes off for new gaskets.
Mon Apr 09, 2012 5:34 pm |
Re: Badlands 66
So this is why you need angled sparkplug boots with the duffs headers.
Tue Apr 10, 2012 8:24 pm |
Re: Badlands 66
for you naysayers.... just a little tease.
Tue Apr 10, 2012 8:30 pm |
