hockeydad4-22 wrote:Gents,
As of 3 days ago I was planning on building with stock bronco axles, upgrading them and that made perfect sense to me. New I am considering dana 60's? Already this has gotten out of hand.
remember, there is no plan for heavy duty, extreme wheelin in my future plans, and if I ever did, I can change the axles then.
The high pinion full width 44, and full width 9" will be more than enough of an upgrade. Might even talk about trussing them ala landsharks recent upgrade.
Besides, I already found them, 2 44's in fact. And all I am going to be out is $200 bones that I will attempt to make up by selling the extra once I swap out the parts I do not need.
I have not mentioned this before but I have a challenge that I can have this thing ready for under 5k. So I need to consider budget as well.
Rox Crusher wrote:
Yeah, whatever dude
A real man would put hummer drivetrain under it
akaFrankCastle wrote:Remind me, are you going full width?
Since you're stretching, and on a budget, maybe throw some F150 rear leafs under it?
akaFrankCastle wrote:Advantages? Not really sure about the mechanical advantages. But at 18 bucks a piece at the U Pull and Pay, financially I'd say they are pretty good.
ZOSO wrote:I have a set of stock rear leaves from a eb. The only thing with the f150 springs are they are 3" wide and not 2.5" like the eb.
kchaser wrote:A lot of 1 ton haters I guess. The only extra expense is the axle itself. Weld some wedges on the front and a track bar mount some perches on the back and bolt them in.
hockeydad4-22 wrote:kchaser wrote:A lot of 1 ton haters I guess. The only extra expense is the axle itself. Weld some wedges on the front and a track bar mount some perches on the back and bolt them in.
Naw - not a hater at all. Just not wanting to build that rig at this time. Might upgrade someday - but for right now - the full width 44 / 9" combo is plenty.
Colorado75bronc wrote:Updates man! What have you done so far?
hockeydad4-22 wrote:Picked up another frame last night from my "twisted" Friend for parts and pieces, as well as a few other needed parts and pieces. Then sat in his garage and enjoyed an excellent cold beverage and chatted about many things.... bronco's, builds, plans, time lines... you know - life.
Tonight the build gets started in earnest.
Mounting axles. I hope to lay out, cut and stretch the frame this weekend as well but much of that will depend on how many other honey-do tasks I am given.
