by Gunnibronco » Mon Nov 26, 2018 7:39 pm
I didn't get as much extra wheelbase out of my spring swap (and pushing my front forward) as I thought either. I didn't measure my wheelbase before I started either. I pushed my front forward as far as I could (leaving enough room to mount the front cage to the frame). After moving the rear axle back about the same as you, I've got 97.25". I thought I would have gained more, but it is what it is. I'll try to get a measurement off my 72 soon if nobody else gets a measurement. It's on an old 3.5" lift, but should be close to stock.
Just eyeballing yours vs mine, front hangers look about the same, my rear hanger might be a little further back. Hard to tell. My shackle is a little more vertical. All I was aiming for on the shackle is past 6 o'clock. I didn't know that a flatter angle would be better for wheeling. I only read you didn't want it pulling forward of 6 o'clock when the axle drooped. Then it could swing forward, and rotate up the wrong way.
I really can't move the axle back much more, I'm already afraid I'll be kissing my gas tank, and it can't be moved back any further. I'm wondering about the condition of my used springs, vs yours. I always kind of thought I'd end up on custom springs. I guess if I go to custom springs, I can gain an inch or so and abandon the stock gas tank and go to an in bed fuel cell. I had always daily driven my truck and I hadn't accepted that it was becoming a dedicated crawler. I wish I had, dealing with the tank was a PITA and I won't be surprised if it gets abandoned eventually.
