That’s such a bummer. My part actually came in less than 48 hours I put it all back together with the old cracked one. I’ve decided to not press my luck and just run it as is instead of trying to fix it last minute.D&D72 wrote:No end in sight for my ARB for the rear. Mine wont be at super cell.
Jesus_man wrote:I am so sorry about the ARB. I hear about more trouble with them than good things. I attempt to steer anyone away from them.
What I can't understand is that with the 9" being such a popular axle, why aren't there more options for a selectable locker??? Someone needs to make an solid E-locker and they could make a killing!! Offroad to drag cars...
I went Chrom-mo's back in 2012-ish and have yet to break one shaft since. I need to be better at maintenance on them (mine require the needle grease fitting), but they have been super solid!
I agree. I also bench tested it at home before installing and also tested it again 2-3 more times in the garage once everything was all back together.BOBS 2 68S wrote:Eck,
I could swear that a set screw was installed. Kirk might remember. I remember it working on the bench.
Yah- I think the housing needs to be looked at for sure. I also have one rear tire that has a lot of outside wear that I haven’t been able to figure out the cause.ZOSO wrote:the axle may not be bent but the housing may. That will cause the axle to rub the ARB. you may have to pull it and have it checked.
Sorry to hear of your troubles. FWIW my arb works like a champ. even my front which is OG from the late 80's.
It is not but I honestly couldn’t tell you if I’ve rotated those tires around to rule anything out.ZOSO wrote:Is the side with the worn tire the side that has the crack on the arb? If you havent rotated tires thats something to think about.
Don’t you still have to remove the transmission to get to it? Just contemplating if I should go ahead and take the extra step of pulling the engine to reseal everything just to make sure I’m hitting all bases.Gunnibronco wrote:I just did my rear main seal. I put it off for 20 years because I was intimidated by the process. It turned out pretty damn easy. I'd consider doing it in the truck. Buy 2 rear main seals, they are easy to damage. Use the Fel-Pro one piece oil pan gasket. Look at your dipstick/oil pan seal if you have that style, and address it when the pan is off.
Add a truss/backbone to your axle to prevent it from bending again?
https://www.ruffstuffspecialties.com/9FACTORY.html
Doesn't this depend on the year? Eck, what year is your 351w out of? I know the later 302's are a single piece rear main.Gunnibronco wrote:I thought the same thing about removing the transmission. Search for Youtube videos and you'll see how easy it is. The rear main is 2 pieces and you only remove the oil pan and rear main bearing cap. I would have done it years ago if I knew you didn't have to remove the transmission.
phyler wrote:Doesn't this depend on the year? Eck, what year is your 351w out of? I know the later 302's are a single piece rear main.Gunnibronco wrote:I thought the same thing about removing the transmission. Search for Youtube videos and you'll see how easy it is. The rear main is 2 pieces and you only remove the oil pan and rear main bearing cap. I would have done it years ago if I knew you didn't have to remove the transmission.
Justin wrote:Mine is a 1989 block. I used the 1 piece rear main.
