Justin's retroactive build thread
Re: Justin's retroactive build thread
Postby Justin » Tue Jun 01, 2021 7:34 pm
Making my usual slow but sort of steady progress. Getting tired of notching tubes....
Postby Digger » Tue Jun 01, 2021 7:46 pm
Looks beefy Justin. Great work!
Postby Jesus_man » Wed Jun 02, 2021 11:22 am
I like it! Notching tube is tedious especially to get right. You'll be happy you did quality work when it's done!
Postby Justin » Sun Jun 06, 2021 8:11 pm
Looks like I found the cause of my oil consumption issue......Image
Postby Viperwolf1 » Mon Jun 07, 2021 1:36 pm
Looks like you have a missing baffle. What intake is that? It's kind of Ford like but kind of not also.
Postby Justin » Mon Jun 07, 2021 1:41 pm
100% missing the baffle. It's an Edelbrock I got used.
Postby Justin » Sun Aug 22, 2021 2:40 pm
Got the engine back together after waiting for 100 years on the baffle from Edelbrock. Major fabrication on the cage is done as well. Need to make a bunch of tabs to tie in the cowl, windshield and pillars, then will pull it and finish weld. Image
Postby phyler » Sun Aug 22, 2021 2:42 pm
Justin wrote:Got the engine back together after waiting for 100 years on the baffle from Edelbrock. Major fabrication on the cage is done as well. Need to make a bunch of tabs to tie in the cowl, windshield and pillars, then will pull it and finish weld. Image
So, you'll be done by next week? [emoji1787]
Looking good! Hope to see you at SC.
phyler
CCB Admin
Postby Jesus_man » Mon Aug 23, 2021 5:37 am
Cage looks nice!
Postby Justin » Sat Aug 28, 2021 8:20 pm
I let Alex drive the Bronco.Image
Postby Jesus_man » Mon Aug 30, 2021 7:43 am
Hope he brought it back in one piece!
Postby Justin » Sat Sep 04, 2021 6:24 pm
Took it for a drive. Cage came out great, although I'm going to have to realign one of the doors. Really like the tie ins for the windshield and cowl, as it totally eliminated cowl shake. Also really happy with the new power steering pump, which has totally eliminated the lag I was getting with my old one (4x4x2 box, hydro assist and hydroboost). I may take it for a longer run tomorrow, but for now I'm pretty happy withthis round of upgrades. Will probably like it even better when my full length bikini top shows up from Wild Horses. Image
Postby Strike2 » Sat Sep 04, 2021 8:42 pm
Nice work that cage turned out sweet! thumbs up
Strike2
Postby Justin » Sat Sep 04, 2021 8:51 pm
Postby BOBS 2 68S » Sun Sep 05, 2021 4:55 am
Looks Great!!!
BOBS 2 68S
Postby Digger » Sun Sep 05, 2021 1:37 pm
That looks great! Nice job!
Postby Gunnibronco » Mon Sep 06, 2021 4:13 pm
Cage came out nice.
What PS pump did you do? Is it an "upgrade" or just replaced with newer pump? I'm wondering how things will do when I add hydroassist to my system. I'm running a Saginaw pump, hboost and 4x4x2 box now. I have some pages saved on upgrading performance of the Sag pump, but wondering if there is another route I should be looking at. I am still running v-belts until my alternator gives up, then I'll probably upgrade to serp (V8 truck or Explorer, not sure which- I have both).
Postby cobshane » Sat Sep 11, 2021 3:50 pm
Your Bronco is a beast. Great work you have been doing! You have picked some awesome skills.
cobshane
Images: 1
Postby Justin » Mon Sep 13, 2021 5:49 am
Hey, thanks!
Postby Gunnibronco » Fri Nov 26, 2021 1:29 am
I'm planning to replace my Bloody Knuckle arms with DOM radius arms. I have someone eager to buy mine.
I'm planning to use the Ballistic radius arm mount/lower coil bucket.
https://www.ballisticfabrication.com/pr ... oil-mounts
This looks a lot like what you used but with the coilover mount instead of coil spring bucket.
Do you have more pics? Maybe I missed them in your thread.
I'm concerned with the angle of the arm into the mount, I know the bushing shouldn't have much stress on them. How did you keep the bushings straight in the mount while "aiming" the arm back at the frame? Did you angle cut the upper and lower tube?
Are your arms are bent or straight? It looks like there might be a bend towards the back of the upper arm bracket.
Metalcloak ends at the frame?
What angle are the frame brackets mounted at the frame, to point the arms out to the axle mount?
How long is the upper arm? Ruffstuff's kit comes with a 24" piece of DOM for each arm, but yours looks much shorter. I don't want to buy more DOM than needed.
I hope my questions make sense.
Thanks
Postby Justin » Fri Nov 26, 2021 11:12 pm
-That's exactly the same as what I used, although I had mine done with shorter distance between the holes where the radius arm attaches to the bracket since my arms were designed with a 6" span instead of a 7" one.
-I did cut out the inner side of the bracket some to angle the brackets more towards the frame, but my arms also have some built in angle to them, so I could run them close to perpendicular to the axle tube.
-My arms have a fairly significant bend in them, which I appreciate since I still rub a little with the 37's.
-Yes, Metalcloak joints. I'm happy with them, although I also haven't run anything else.
My brackets are parallel to the frame, mostly due to the bend in the arms.
-24" of DOM should be plenty. When you figure in the heims and sockets, it's more than enough. The tube portion of mine is 6-7", not including the other hardware.
I can get better pics when it's light out if helpful.
Postby Gunnibronco » Fri Nov 26, 2021 11:39 pm
Thanks that helps a lot.
I'm hoping to keep the arms straight. I guess I won't know if the tires rub until I can put a finished axle under it. Not sure how the D60 knuckles will fit/turn compared to the D44.
I was thinking of offsetting the brackets or possibly putting a bend in them to 'point' them at the frame brackets. My frame brackets are mounted slightly angled out, but not a lot.
I guess it's a wait and see situation.
Postby Justin » Sat Nov 27, 2021 12:21 am
I just angled the axle brackets in some by grinding out the 2 inner plates where it contacts the axle tube and it worked great. Seemed much easier than having to accurately repeat bends across the 4 plates. When we did the DIY radius we bent the tube using a Harbor Freight pipe bender. Sketchy as heck, but it worked. Even did 1 set in a parking lot. If I had it to do over I'd probably have it done by someone with a proper bender. I thought it was worth it, but your mileage may vary.
Postby Gunnibronco » Sat Nov 27, 2021 8:35 am
Justin wrote:I just angled the axle brackets in some by grinding out the 2 inner plates where it contacts the axle tube and it worked great. Seemed much easier than having to accurately repeat bends across the 4 plates. When we did the DIY radius we bent the tube using a Harbor Freight pipe bender. Sketchy as heck, but it worked. Even did 1 set in a parking lot. If I had it to do over I'd probably have it done by someone with a proper bender. I thought it was worth it, but your mileage may vary.
Thanks.
Postby Jesus_man » Mon Nov 29, 2021 8:39 am
Are you concerned with the the tube axis being perpendicular to the bushing axis? My brackets are perpendicular, and I just cut the tube at the appropriate angle to get them to point towards the frame bracket. I don't believe this to cause any additional stress to the bushings as if one side pushes, the other side pulls, if that makes any sense.
Postby Gunnibronco » Mon Nov 29, 2021 9:16 am
Jesus_man wrote:Are you concerned with the the tube axis being perpendicular to the bushing axis? My brackets are perpendicular, and I just cut the tube at the appropriate angle to get them to point towards the frame bracket. I don't believe this to cause any additional stress to the bushings as if one side pushes, the other side pulls, if that makes any sense.
I just read the bushings shouldn't have more than 5* of misalignment or you need to use a heim joint.
I've rethought things and will be moving the springs back to stock width, this will minimize angles with straight arms while keeping a good turning radius.
Postby Jesus_man » Mon Nov 29, 2021 9:55 am
Huh. I'll bet mine are more than 5* out, but I would have to look closer. I do think I recall replacing the bushings once, perhaps with poly?? Again, my memory is weak.
Postby Justin » Sun Dec 12, 2021 6:26 pm
When I built the cage, I welded in some spots for interior lights, as my Bronco has never had them and it's annoying. Finished up the install and wiring today, since it's finally cold enough to think about running a top. I'm now considering renting it out to a grow operation on the side.
Postby phyler » Sun Dec 12, 2021 7:39 pm
I don't know if I've ever had light in my Bronco. That goes for the instrument cluster, overhead, anything. That looks pretty amazing.
phyler
CCB Admin
Postby Eck » Sun Dec 12, 2021 9:37 pm
So many easy LED options now make it a no brainer to add lights. Looks good!
