It is currently Sat Sep 28, 2024 1:02 pm
Moab Mike
Re: Badlands 66
Rob, you are awesome!
Tue Apr 10, 2012 8:35 pm |
Badlands
Joined: Mon Apr 25, 2011 9:02 pm Posts: 340 Location: Littleton
Re: Badlands 66
Tue Apr 10, 2012 8:37 pm |
Re: Badlands 66
Nice job man! Now on to the fun stuff.
Tue Apr 10, 2012 9:11 pm |
Re: Badlands 66
Just a little update. trouble shooting the idle issue now with howell. It either hunts real bad and stalls or idles at 1400rpm. So with their help hope to have that figued out. The starter went out saturday. Had to pick up a new one and got that put in. I think I have all the leaks fixed except for one. The trans linkage leaks.
Mon Apr 16, 2012 6:37 pm |
Re: Badlands 66
Finally got a hold of howell. Need to get my sideband installed and get a number off the cal prom and get that info to them for a new cal prom. It wont idle because it seems to be running way lean.
Thu Apr 19, 2012 7:22 am |
Re: Badlands 66
It's all in the fuel pressure. Once I ppinched off the return line to raise the pressure at the injectors the hunting idle stopped and it runs. Now to pull the throttle body off and try to make a permanant adjustment. Also need to find a different fan. This one is too deep. Does not pull air through the radiator.
Sun Apr 22, 2012 12:54 pm |
Badlands
Re: Badlands 66
Atta baby!
Sun Apr 22, 2012 1:45 pm |
Re: Badlands 66
Sun Apr 22, 2012 2:56 pm |
Re: Badlands 66
The other fan is the same way. Also got a fuel pressure gauge to put in the line to check it.
Sun Apr 22, 2012 3:31 pm |
Badlands
Re: Badlands 66
Sun Apr 22, 2012 3:49 pm |
Re: Badlands 66
Steve was itchin to burn rubber at breakfast
so near the finish line !
Sun Apr 22, 2012 7:06 pm |
Re: Badlands 66
After running all the tests that howell suggested they are sending a new ecu cal prom. Should be here in a few days.
Wed Apr 25, 2012 7:18 am |
Re: Badlands 66
Haha yea probably. Waiting for the new cal prom to show up. Plus I leave tomorrow for a week on vacation.
Fri Apr 27, 2012 6:21 am |
Re: Badlands 66
Fri Apr 27, 2012 7:07 am |
Re: Badlands 66
No extended vacation. The parts should be here when I get back so you have till next weekend to get yours running and driving. If that cal prom works then ill be deriving it next weekend.
Fri Apr 27, 2012 7:27 am |
Re: Badlands 66
IT DRIVES!!!!!!Video coming soon.
Fri May 04, 2012 9:58 am |
Badlands
Re: Badlands 66
Woo hoo!!
Fri May 04, 2012 10:43 am |
Re: Badlands 66
No big burn out yet. Just a little one backing in the garage. Want to get miles on it first.
Fri May 04, 2012 11:14 am |
Re: Badlands 66
I would if it was mine. I don't know how this motor was built.
Fri May 04, 2012 11:18 am |
Re: Badlands 66
Crappy quality but its proof.
Fri May 04, 2012 11:43 am |
Re: Badlands 66
Fri May 04, 2012 12:54 pm |
Re: Badlands 66
Rob, that camera clipped to your hat?
Sure sounds nice!
Fri May 04, 2012 1:14 pm |
Re: Badlands 66
Trying to hold my phone and drive.
Fri May 04, 2012 3:07 pm |
Badlands
Re: Badlands 66
Fri May 04, 2012 9:17 pm |
Re: Badlands 66
Sat May 05, 2012 7:24 am |
Re: Badlands 66
broncobuster
Joined: Thu May 03, 2012 10:04 am Posts: 3 Location: Bailey, CO,
Re: Badlands 66
Great job!!
Is the video of the burn out real? For us new folks, is it really a Pontiac engine?
An all wheels burn out is called for!
Terry
Fri May 11, 2012 5:33 pm |
Badlands
Re: Badlands 66
Fri May 11, 2012 5:47 pm |
Re: Badlands 66
Got the gauges working now it has water temp. Got it running pretty darn good. Installed a new alternator so now it charges. Need to hook up the kick down cable and it's time to put some miles on her. Hope the weather holds out saturday so I can go for a spin for more than around my neighborhood. Looking to drop it off next week for new exhaust.
Fri May 11, 2012 7:11 pm |
Re: Badlands 66
Got most of the bugs worked out. Put 5 miles on it yesterday. Ran it to the gas station and filled it up. 80$ freaking bucks. Plan to drive it today. Gonna have to tear down the front suspension. Needs to have the caster measured and fixed. It wanders really bad. Steering doesn't return to center while driving. Kinda a scary to drive.
Sun May 13, 2012 7:17 am |
