Not my rig but my project "Siamese Dream"
Re: Not my rig but my project "Siamese Dream"
Postby Kinder » Thu Sep 08, 2016 3:29 pm
Too long, nah! I will be moving the axle fwd an inch or two.
Postby akaFrankCastle » Thu Sep 08, 2016 8:41 pm
You're going to need a CDL soon.
Postby Viperwolf1 » Thu Sep 08, 2016 8:44 pm
You should mount the front half of a Bronco on it, maybe add a mother-in-law seat too.
Postby Kinder » Fri Sep 09, 2016 4:42 am
CDL, check. MIL seat, um no!
Postby Jesus_man » Sun Sep 11, 2016 9:54 am
It does look disproportionate but throw an ATV on it and I think it'll be perfect.
Postby Kinder » Wed Sep 14, 2016 4:42 am
Hauled my 1st item that otherwise wouldn't have fit, it did great.
Postby Jesus_man » Wed Sep 14, 2016 7:34 am
Awesome!
Postby Zenzone » Wed Sep 14, 2016 7:53 am
Kinder, that trailer is looking Great! Good work!
Zenzone
Postby Kinder » Wed Sep 21, 2016 6:28 am
Quick & dirty rear bumper w/ receiver built out of spare pieces from a old front PTO bumper. This'll allow a third stabilization jack when RTT is in use.
Postby Viperwolf1 » Wed Sep 21, 2016 10:49 am
kinder wrote:This'll allow a third stabilization jack when RTT is in use.
Or a caboose.
Postby Eck » Wed Sep 21, 2016 11:16 am
Or a caboose.
Or another rear driven BSD...
Postby Kinder » Wed Sep 21, 2016 12:39 pm
Eck wrote:
Viperwolf1 wrote:
Or a caboose.
Um, how did you fellas know I was going to power the trailer axle via PTO!?!?
http://www.youtube.com/watch?v=K4JwHQ0PbAU&sns=em
Postby Jesus_man » Wed Sep 21, 2016 2:14 pm
Postby Kinder » Sat Oct 01, 2016 5:23 am
Loaded up the quad for a test run, it didn't fall off and doesn't stick out past my mirrors!
Postby Rox Crusher » Sat Oct 01, 2016 6:00 am
Those elk don't stand a chance
Postby Kinder » Sun Feb 25, 2018 6:40 pm
Swapped out the trailer axle w/ electric brakes for the old BSD 9”. I’m adding a electric over hydraulic actuator to operate the trailer brakes and keeping the e-brake cables and attaching them to a commercial hand operated affair for parking it. Mocked up the old front driveshaft out of the ‘79 that I parted out as well, right now I’m thinking carrier bearing to the next section of driveshaft. The hubs will spin free until I sort out the PTO off of the 203 or 205 in BSD. I’ll need to re-engineer the simple hitch to a 2 or 3 point affair so the driveshaft connection works. WWII troop carrier Volvo’s had powered trailers so I’ll use that for inspiration. 6x6 here I come, yeah I’m at that level of crazy.
Almost forgot to mention that I’ll need to sort out the right gear ratio to keep the 35s and not bind up the driveline. If not feasible the trailer with get 37s, geez I am crazy.
Postby Jesus_man » Mon Feb 26, 2018 8:10 am
Well I, for one, admire your craziness!! What a fun project! I'll be interesting to see how a powered trailer handles!
Postby Kinder » Sat Nov 27, 2021 10:24 am
Yes, it’s ridiculous, just here to provide entertainment!
37s all the way around now.
Postby Jesus_man » Mon Nov 29, 2021 8:31 am
Sweet!! A little paint and it would transition from ridiculous to amazing!
Is the fuel tank in tack?? That would be a great spot to store extra!
Postby Strike2 » Mon Nov 29, 2021 9:02 am
That's sweet! So do you carry a spare 37" on the trailer and the rig?
Strike2
Postby Kinder » Thu Dec 02, 2021 7:10 pm
Ha, a “little” paint is needed for sure, some day in the distant future there might be a rattle can in my hand on a warm day.
A 23 gal fuel tank occupies the original space, it’s plumbed with a remote fuel pump, 1 way valve and quick connect. I can throw a switch in the cab and it pushes it to my main tank on BSD. With the main, aux and trailer tank full I can push 1000 miles before I refuel if I keep my foot out of it.
I don’t have a 37” spare for it yet, it will get one when I find something cheap. I thought of changing the bolt pattern from 5 to 8 lug so one spare could ge between BSD and the trailer or use adapters. The biggest problem is the offset, the rims on BSD are offset to tuck tires in with full width axles and the trailer offset is set so the tires will tuck into the wheel tub on a stock width axle.
Previous
