LIKE
mickphatmac wrote:Dang you do good work!!!!!!!!
LIKE
Gunnibronco wrote:Shimming the bodymount under the driver's feet will lift the door & pillar, helping to lift the back of the door, in relation to the quarter panel. If your underfloor brace is bent this will help compensate for that.
Shimming under the mount behind the drivers seat will lift the 'b' pillar & quarter, and possibly make the door to quarter gap wider at the top.
Shimming under the rear most body mounts will lift the rear end, closing the door to quarter gap at the top.
These bodies are very flexible. I did lots, and lots of adjustments through my current rebuild. I left all the body mounts loose & got the lines right. Then tightened down all the mounts at the same time. My gaps pretty much stayed the same.
Use lots of screws, like Justin said. I noticed when I was testing my doors, using 2 bolts in each hinge to body, instead of 3, allowed the hinge to move off the post when the door closed. These doors are heavy.
During a conversation I was having with the owner of Big Sky Broncos, he said that most the new door posts need work before they are installed. Most have bows of some degree.
