Jesus_man wrote:How tall are you? I'm 6' and just installed very low pro seats. Anything impeding the top of the windshield would be in my way. But I LOVE the sleek look of the rack!
Kinder wrote:Nice, the KCs will add some vintage love, I hope you put the smiley face covers on them.
sykanr0ng wrote:KC also makes LED inserts for their regular housings.
EFI Guy wrote:Is the outer bar part of an EXO or will it tuck into the fender?
Gunnibronco wrote:I like the idea, and this is the first I've seen it done like this. I've been running 79 44 & 9" for a while now. When I swapped to the wider axles, I was running a 10" wide rim w/3.5"? backspacing (33x12.5 tires). My tires hung way outside my old school traditional Bronco flares. The biggest issue for me was mud. If I was driving on a muddy dirt road, the tires would throw mud all over the windows. It didn't take long before I literally couldn't see out any window of the truck. I installed the Wild Horses wide flares (Silverbacks) and it fixed the problem. I wasn't wild about the look, but I got used to it, and now they look fine to me. Plus they served a function, and made a big difference. I've switched to an 8" rim w/similar backspacing. It pulled the tires in under the truck a lot, and I'm not sure if I'd need the wider flares at this point. I'm not 100% sure how wide they are, I can check if you want.
hockeydad4-22 wrote:I am paying close attention to this build. Lots of really great stuff!
Strike2 wrote:Thanks,
yes if you get a chance I'd be curious how wide they are? I felt 3.5 was ok for a 12.5 and hope I can stick with a 35". here is a side shot of the tube fender along with my XJ flares and how skinning them makes them look, its a long welding process and hope they look good on the Bronco.
Gunnibronco wrote:Strike2 wrote:Thanks,
Jesus_man wrote:I agree the oval lights make it too busy back there. But I LOVE the suspension. King has come a long way!
Strike2 wrote:Would painting the hood black on my Bronco be considered a "poser" move in the Bronco community?
That tailgate came out nice! I may have to hit you up for some tips as my summer goal is to get the body work done and some paint on mine. [emoji16]Strike2 wrote:Bronco weights in at 3,878lbs w/26gals fuel and fully loaded, minus passengers, oil, coolant. So I ordered up my shocks and they should be here Wednesday which is great timing as I'm heading out to Phoenix on Wed for a week. I've taking a few days off from working on the Bronco to paint a black to silver tailgate for my neighbor, it sure is a nice break from doing metal work!
D/F 998lbs P/F 1032lbs
25.8% 26.3%
D/R 966lbs P/R 882lbs
24.9% 22.6%
25.8% 26.3%
24.9% 22.6%
