Project More Metal
Re: Project More Metal
Postby Jesus_man » Tue Mar 05, 2019 12:04 pm
That's looking great!! I'm scared of tackling the inner fenders on my own, which is one thing holding me back from pushing my rear axle.
Postby dbasile » Tue Mar 05, 2019 3:17 pm
Don't be scared......its just sheet metal, if you don't like cut it out and try again.
dbasile
Postby Jesus_man » Tue Mar 05, 2019 4:27 pm
As you know, there are other obstacles. I have no experience with body work, so I think that is my largest obstacle (well aside from $$), but I will be watching what you do closely. I have seen others too and it seems pretty straight forward. Perhaps if we end up moving to a location with very little wheeling, I will tear into it! I just don't want to end up with my bronco out of commission for more than a few months.
Are you going to run flares?
Postby dbasile » Tue Mar 05, 2019 11:03 pm
I get it. I just hope I keep up with my goal and it's out of the garage by spring. I did not know anything about body work prior to this project either. I am learning as I go....I feel like I am getting better.
dbasile
Postby Strike2 » Thu Mar 07, 2019 6:19 am
Looking good dbasile!
How much of the rear outside wheel well are you trimming if any?
Strike2
Postby dbasile » Fri Mar 08, 2019 11:20 am
So this is what I laid out for the rear opening, it kind of matches the front of the opening plus it gives me enough room to step up to 40s if so desired later.
dbasile
Postby dbasile » Fri Mar 08, 2019 11:26 am
I like the added capacity of the aero tank, but not the added depth. Installed as is the bottom of the tank sat low, it was about the same height of the springs. I opted to make some small changes to the floor to tuck it a little.
dbasile
Postby Strike2 » Fri Mar 08, 2019 12:07 pm
Heck Yea!
That's what I like to see, someone who's not afraid to use a cut off wheel it just sheet metal lol. The added clearance is a must thumbs up
Strike2
Postby Jesus_man » Fri Mar 08, 2019 12:53 pm
I like it!! Will your rear axle hit the tank on compression?
Postby dbasile » Fri Mar 08, 2019 3:17 pm
I should have about a 1/2 to 3/4 inch space between the tank and axle on full compression. Hope that's enough
dbasile
Postby dbasile » Mon Mar 11, 2019 10:09 am
Big progress this weekend! Front axle is in place, well kind of. It clamped in.
I am going to change the location of the track bar. I don't like where it is, it hits the cross member on compression giving me about 1 inch less up travel. My plan is to have it directly on top of the axle from a riser at the original mount to the frame. There seems to be more than enough room.
So far I am not 100% sold on the placement of my steering box, it too limits my up travel. I am wondering if pushing it forward a bit or up will help.
dbasile
Postby Gunnibronco » Mon Mar 11, 2019 10:16 am
It looks like you are using the F150 box with a forward facing pitman arm. I reversed the valving & pitman arm and pushed the box forward. I also moved the track bar forward and found a sweet spot where the long arms hit the frame before anything else stops up travel. I figure that is the best I could do.
Edit: I am using the 78/79 F150/Bronco steering box w/reversed valving (4x4x2 box). Totally different box after closer inspection.
Postby Jesus_man » Mon Mar 11, 2019 11:50 am
As for the track bar, it is better practice for a wheeling rig to put the riser on the axle, and keep the pressure off the frame by running a short bracket. It's hard to see here, but after plating the frame, I made a frame bracket from a short piece of 2x6 steel. It is welded to the bottom and vertical side of the frame.
Here's a better pic:
Postby dbasile » Mon Mar 11, 2019 8:19 pm
So the box is a stock 79 bronco. Went with it to avoid cutting the grill to get the forward push I wanted.
The plan was to add the riser to the axle and mount the upper on the bottom of the frame right behind the spring.
Jesus_man can you post a close up of your upper spring mount? I've seen something similar on a jeep, does it allow that much more droop?
dbasile
Postby Gunnibronco » Mon Mar 11, 2019 9:37 pm
dbasile wrote:So the box is a stock 79 bronco. Went with it to avoid cutting the grill to get the forward push I wanted.
Something looked different to me. It maybe hanging lower than mine. All my bolts went through the frame. I thought about keeping the pitman arm forward. I'm maxed out moving the axle forward at about 2".
Postby dbasile » Tue Mar 12, 2019 8:58 am
When I was checking how to mount the box, I just put it on the frame and clamped it down. I researched how people mounted the 4x4x2 box since the exterior of that one and mine are the same. It was about a 50-50 split of people who would let rest on the frame and make a lower bracket and people who would use what existing holes they could.
On my initial trial, I did not like the fact my up travel on the driver side was going to be limited by the drag link hitting the pitman arm. Just on first glance, it looks like I could gain a couple of inched by raising the box. Before I drill any holes or weld anything in on the steering, I think I will try another location or 2 for the steering box to see what I like the most.
Gunni, I re-examined your build thread, your bolt holes did all go through the frame. I think that will give a much more positive feel in the steering.
dbasile
Postby Jesus_man » Tue Mar 12, 2019 9:55 am
dbasile wrote:Jesus_man can you post a close up of your upper spring mount? I've seen something similar on a jeep, does it allow that much more droop?
That is indeed where I got the idea. A good one? Well, lets just say that it was far cheaper than getting new springs. My springs are old and very stiff and would not allow my axles to droop. So I did this with good results other than some rattling and squeaking on the trail as the spring rubs on the post. Perhaps a smaller OD tube would be better. This is a bandaid fix for now. Ultimate goal is to get longer springs using weld on adjustable coil towers, that flex better. Then perhaps I can clamp the top of the spring again as they are from the factory.
I don't know that I have a close-up, but it's simply a piece of 1 3/4" HREW welded to 1/4" plate that was just initially bolted thru the factory hole until the bolt snapped off. So the trail fix was to weld them on. I am happy to get a better pic if you think you want to try this.
Postby dbasile » Mon Mar 25, 2019 2:00 pm
Well I have been continuing diligently in the garage on all of my off time, minus a little skiing here and there. My wife has continually referred to my bronco as my mistress.....(I'm sure I'm not the only one).
I am almost sure I will miss the first deadline of Easter Jeep week. Oh well, however progress is being made.
I welded the radius arm brackets to the frame, the coil buckets. First time since fall she sits on her own weight! In the end I have pushed the front forward about 6".
dbasile
Postby dbasile » Mon Mar 25, 2019 2:15 pm
After I got everything mostly good, I need to see how the wheel looked. So, I think I still need to trim sheet metal.
The wheels have a lot of offset, in order to run TRO with the one tons, I need to get some spacers. My friend had some 1.25" spaces he let me use to see what my clearances looked like. It would be enough for the tie rods but still would contact the shock mounts. I went with 2" to allow full lock without contacting the shocks.
I will wait till I get the spacers until I trim the sheet metal.
dbasile
Postby Jesus_man » Mon Mar 25, 2019 5:23 pm
I love the plating you did on the coil towers where they weld to the frame. I want to do that as well when I finally get the chance to install my adjustable towers. What springs are you running vs net lift? I'm thinking 5 or 6 " lift springs but only netting about 3" lift.
Postby dbasile » Mon Mar 25, 2019 5:30 pm
The springs are 5 1/2" duffs I found used. I hope to end around 3 1/2-4" if lift. I may have to change the height of the towers once I get some more weight in the truck
dbasile
Postby Jesus_man » Tue Mar 26, 2019 10:14 am
I'd love to know where you end up.
Postby dbasile » Tue Apr 09, 2019 10:03 am
So the progress is coming along. I feel that some times I am just spinning my wheels. I have finally installed the transmission and transfer case for good, this time, maybe...... along with triple stick for the transfer cases. I needed to trim a little more metal. When I got everything looking good there, I bent up a tunnel cover.
dbasile
Postby mickphatmac » Tue Apr 09, 2019 10:36 am
Never did anything like that before Huh???
Looks really Awesome!!! You give me hope that I can still do my own floor pans!
Keep Going, Very Cool!!!
Images: 14
Postby dbasile » Tue Apr 09, 2019 2:29 pm
Fake it till you make it! I never did anything this in depth before. I have never been afraid of something new either. The best part of you don't like the way it turned out so it again till you do. Sheet metal is sort of cheap
dbasile
Postby Strike2 » Tue Apr 09, 2019 7:17 pm
Your tunnel cover came out great Nice Work thumbs up
Strike2
Postby dbasile » Sat Apr 27, 2019 12:04 pm
So I went down into the garage Friday morning......and saw this. The plan is to leave Monday in the AM to got to Moab for Bronco Safari. I will have some long days.....I only have to plumb the brake, fuel, air, run the exhaust,replace the wiring harness, replace the interior, make at least 2 more frame tie ins for the roll cage, figure out the ebrake, fill all of the fluids and bleed everything...not too much maybe
dbasile
Postby dbasile » Mon Apr 29, 2019 7:16 am
Well its Monday morning and I am supposed to be packing for Moab and the Bronco Safari. I got a lot done yesterday, but not enough. At some point I removed by power steering pump for some reason, not sure why. When I went to put it back on, my water pump began leaking a little. I didn't think much of it and figured it would stop as soon as I got the bolts back in place. Nope, still leaked. There was't a store in town that had the gaskets either, I used the 'right stuff' to seal it, I hope I don't regret it later.
It also seems like I knock one or two items off of my punch list and 2 or 3 pop up that go onto the list.
I hope it is done today...........
dbasile
Postby Strike2 » Mon Apr 29, 2019 9:19 am
Just keep wrenching!!
Guys don't need to pack anything, remember they have everything you could every need at truck stops icon biggin
Strike2
Postby Jesus_man » Mon Apr 29, 2019 9:21 am
Keep at it!! Hope things go smoother today!
