74 Baja Race Bronco - Baja or Bust
Re: 74 Baja Race Bronco - Baja or Bust
Postby Strike2 » Mon Dec 17, 2018 1:22 pm
Looks awesome Chris! it sure was a nice weekend in CO for working this weekend I also took full advantage.
Strike2
Postby landshark » Wed Jan 16, 2019 10:31 pm
A few more things checked off and wiring has started
Postby Rox Crusher » Wed Jan 16, 2019 11:28 pm
I realize it’s not a rock crawler but I have a set of LED rock lights I am willing to donate to this project.
Let me know.
Postby landshark » Thu Jan 17, 2019 7:29 am
Rox Crusher wrote:I realize it’s not a rock crawler but I have a set of LED rock lights I am willing to donate to this project.
Let me know.
I’ll take em! I have one set but would love another to spread them out.
Postby Jesus_man » Thu Jan 17, 2019 9:46 am
You might need to be working on it at night, so they could come in handy!
This rig is looking sexy!!!
Postby landshark » Mon Feb 04, 2019 8:24 am
Doesn’t look like much has been done but we have officially turned the corner on electrical and plumbing. Just missing a few connections for each, electrical is about 95% done and tested. I will go out on a limb and say we are two weeks away from firing it up. Maybe a run around the block.
As always when you fabricate or customize everything we are having to install - tweak - then re-install to get things where we need them. Very time consuming but worth it.
Postby Jesus_man » Mon Feb 04, 2019 9:36 am
I am nearly as excited as you are!
Does the spare tire clear the cooling fan ok?
Postby hockeydad4-22 » Mon Feb 04, 2019 9:40 am
thumbs up
Amazing work this far Chris!
Postby landshark » Mon Feb 04, 2019 11:42 am
Jesus_man wrote:I am nearly as excited as you are!
Yes, clears fine - should be some photos previously of it mounted
Postby Kinder » Mon Feb 04, 2019 2:58 pm
Your killing it!
Postby Digger » Mon Feb 04, 2019 3:16 pm
Looking great!
Almost too nice to race.
Postby Rox Crusher » Mon Feb 04, 2019 7:11 pm
When is the fire up party ?
Looking great !
Postby landshark » Mon Feb 04, 2019 10:43 pm
Rox Crusher wrote:When is the fire up party ?
Looking great !
Soon
Postby Strike2 » Wed Feb 06, 2019 6:42 am
The Bronco is looking Awesome Chris, nice work!
Strike2
Postby landshark » Wed Feb 06, 2019 7:57 am
Strike2 wrote:The Bronco is looking Awesome Chris, nice work!
I have your calendar. Do you want me to mail it to you? If so pm me your address.
Postby landshark » Mon Feb 18, 2019 8:32 am
#35 is ALIVE! Started right up with the help of some fuel priming. Have a few gremlins but overall pretty solid so far. Should be ready to do a lap this weekend and then start buttoning things up for shake down and paint.
Postby Strike2 » Mon Feb 18, 2019 9:08 am
Motor sounds terrific and is rock solid!! congrats on a huge milestone.
Strike2
Postby Jesus_man » Mon Feb 18, 2019 9:13 am
Wow, I'll bet that feels amazing!! Great work! Can't wait to see some laps!
Postby Moab Mike » Mon Feb 18, 2019 4:45 pm
Nice work Chris!!!!!!
Moab Mike
Postby BroncoRaider » Mon Feb 18, 2019 5:43 pm
Sweet coolant reservoir.
BroncoRaider
Postby pgilbeau » Mon Feb 18, 2019 5:54 pm
That's awesome!
pgilbeau
Postby Rox Crusher » Mon Feb 18, 2019 7:18 pm
Dreams becoming reality !
Postby D&D72 » Mon Feb 18, 2019 11:26 pm
Nice!
D&D72
Postby landshark » Mon Feb 25, 2019 10:34 am
Last major fabrication is done, Front suspension and steering is complete just needs some paint and a few details tidied up to be 100% up front. Somehow we got air bumps stuffed into the motor mounts, they are not at an ideal angle (8-9 degrees off vertical) but for the wheel travel and lift we are running its pretty damn impressive that they fit at all and allow full up travel. i will probably add some shortened poly bumps on the frame as emergency stops as the first thing that would hit if an air bump fails is the trac bar and diff case with oil pan.. Hopefully get the brakes bled this week and take a run around the block before the next round of snow hits. 60 days left!!!!
Postby Digger » Mon Feb 25, 2019 3:13 pm
Looking sick!
Postby Rox Crusher » Mon Feb 25, 2019 6:35 pm
Great progress guys, keep up the momentum.
Postby Jesus_man » Tue Feb 26, 2019 9:57 am
60 days??? Wow! Do you know if there will be any streaming support for this event? I would love to try and watch or even just listen in.
Postby landshark » Tue Feb 26, 2019 10:12 am
Jesus_man wrote:60 days??? Wow! Do you know if there will be any streaming support for this event? I would love to try and watch or even just listen in.
We will have satellite trackers in the Bronco and if they are functioning you will be able to track us along the course. In addition, last year NORRA had a live stream every day at the start, finish and few places around the course. Every year the coverage gets a bit better so hopefully they continue that. I will post up info as it gets closer or you can visit the NORRA website as they will post links up there eventually.
Postby landshark » Tue Mar 12, 2019 4:40 pm
45 days.
It’s now out of paint and back home for “final” assembly.
Paint teaser :)
Postby mickphatmac » Tue Mar 12, 2019 5:23 pm
Hmmmmmm.....
Images: 14
