Jesus_man wrote:What a great project and the knowledge you boys are gaining will benefit you for your entire life. It will also benefit your eventual family!!
BTW - do you know any back story on this ole girl?
CamTheRam17 wrote:Just dropped the Auxiliary tank, its cracked and leaks so we'll need to find a replacement.
If it's the stock block it's called an H-block. It was used to detect if there was an imbalance between the front and rear brakes. If there was, it would light the brake warning light.CamTheRam17 wrote:Also got the brake lines ran from the master cylinder to the connector on the frame (still not sure of the name)
phyler wrote:If it's the stock block it's called an H-block. It was used to detect if there was an imbalance between the front and rear brakes. If there was, it would light the brake warning light.CamTheRam17 wrote:Also got the brake lines ran from the master cylinder to the connector on the frame (still not sure of the name)
