I bought a 1970 from an acquaintance who owned/loved it for many years, but tore it apart to do a restoration.
Actually he pulled the motor so he could put in power steering, saw some rust, and then tore the Bronco apart. I met him when the Bronco was apart, floor pans and an inner fender removed, and the project stalled. I told him I would be interested in buying it, but he was not selling. I wanted something I could just use in the mountains that I liked, a classic Bronco was at the top of my list. I had a 69 Bronco in my early 20's and regretted selling it, but life moves on sometimes. So years later when he changed his mind (in 2014) I knew I had to jump at it.
My intention all along was to just put it back together. Basically reverse the restoration that was started.
I didn't take many pictures, I'm generally bad at remembering to take pictures, but I managed to take a few after the floor pans were welded back in, in the "early days".
Fast forward some ridiculous amount of time (8+ years??!!) with
many other projects taking priority. Now it's time to get it back on the road.
The engine ended up being damaged with a bent nose of the crank, so I picked up a 125k mile 5.0 out of a 96 Bronco. I put a carb on it and removed the serpentine setup. That engine just went in this month, and I'm hoping to have it running this week. It was a running unit when it was pulled so I don't expect it to be an issue. I still have to get an exhaust system before it is road worthy.
I still have a ton of stuff to do on it but I can see the light at the end of the tunnel. Once it is running and drivable, I'm much more likely to work on it. I'll throw some random pics in here.
I love that there is a Classic Bronco forum for Colorado, and I hope to go to some of the meetups.
1970 Bronco, 302 roller + carb, front disc. Bought in pieces, now just putting it back together.
