It is currently Fri May 03, 2024 12:29 pm
Re: Just gettin started...
Looks good!!
Sat Nov 14, 2015 6:30 pm |
:drool: So nice!
Mon Nov 16, 2015 4:59 am |
My Christmas present to myself!
Still a couple weeks away but Viperclaus sent me a teaser... Thank you, ThankYou, THANKYOU!!!
Fri Jan 15, 2016 12:29 am |
BooYa! Putting in some work Boy!
Trying to clean up some of the PO's handy work, lucky for me, It'll get covered by carpet!
¡Adios Manual, Hola Automatic!
Thu Feb 11, 2016 10:16 pm |
should have waited to patch the floor till after the auto is in. Not a lot of room to do much under there.
Fri Feb 12, 2016 8:50 am |
Don't forget to pull that pilot bearing out of the crankshaft.
Fri Feb 12, 2016 9:26 am |
Fri Feb 12, 2016 10:38 am |
Pack the center of the bushing and the void behind it with axle grease or wet bread. Pack it. Pack it good. http://youtu.be/IIEVqFB4WUoThen take a dowel rod, insert it into the hole, and tap it with a mallet. The bushing will work itself out.
Fri Feb 12, 2016 11:05 am |
Mon Feb 15, 2016 9:54 am |
3 Speed...Adios!!!
C4....up and running! Thank you Viperwolf1!!!
Finished putting in the Front Carpet, Seats, and had to install windshield wiper cover, and sunvisors.
I'm done for a while! This was starting to feel like Work!
Fri Mar 11, 2016 12:38 pm |
Nice!
Fri Mar 11, 2016 1:21 pm |
Fri Mar 11, 2016 4:48 pm |
Too Funny LOL!!!!!!!!
Fri Mar 11, 2016 4:49 pm |
My Father's Day gift to myself, new three-point shoulder harness for the rear seat. It came with all new eyebolt hardware that installed in the stock seatbelt positions for that custom-stock look.
After my boys help me do the install we all went for a ride to A&W and got some Rootbeer floats, Sweet!!!
Sun Jun 19, 2016 2:53 pm |
Those look slick. Where did you get them?
Sun Jun 19, 2016 5:13 pm |
A word of caution. having the shoulder straps bolted low like that to the floor can and will cause very bad things to happen in the event of an accident. having them bolted low will compress their spine in the event.
Sun Jun 19, 2016 6:50 pm |
What Rob said. The forward movement of a body in a crash causes straps set up like that to put serious downward pressure on the spine, and can cause severe spinal injuries. To be safe you'll need to add a cross bar at shoulder height, then run the shoulder straps over that.
Sun Jun 19, 2016 9:34 pm |
Sun Jun 19, 2016 10:59 pm |
Sun Jun 19, 2016 11:02 pm |
Ideally, the harness bar should be at or slightly below shoulder height. Most harness makers recommend a 0-20 degree downward angle from the shoulder to the mounting point
Mon Jun 20, 2016 12:02 am |
Looks like your roll bar lends itself to allowing you to add that cross-bar. The position is tough for growing kids tho!!
Like Justin said, 0-20 deg which usually ends up being 1" below shoulders.
Mon Jun 20, 2016 12:11 am |
Mon Jun 20, 2016 3:45 pm |
Welcome. That's a good article. Simpson's install inductions area also quite good if you want a shorter version.
Mon Jun 20, 2016 6:34 pm |
Users browsing this forum: No registered users and 19 guests |
