www.ColoradoClassicBroncos.com :: View topic - 69 Dudes-- Just the beginning
http://coloradoclassicbroncos.com/
http://coloradoclassicbroncos.com/viewtopic.php?f=3&t=4748
Page 14 of 14
Author:  Eck [ Tue Sep 26, 2023 10:44 am ]
Post subject:  Re: 69 Dudes-- Just the beginning
So Phyler convinced me to use a sleeve and just pull the transmission and replace the rear main that way.
https://tdmotion.com/product/1985-1997- ... epair-kit/
I am really hoping this will resolve my excessive oil leak. If it doesn't-- I guess I can start looking elsewhere.
Also-- for those that saw my earlier post about my bent housing, I took it to Western Drivetrain. I also just had them remove and replace a Set20 bearing on a rear axle.
http://www.axleandgear.com/
Author:  Gunnibronco [ Tue Sep 26, 2023 10:50 am ]
I've had good luck using those sleeves. I used one on my old 9" axle and one on my ZF input.
When I was reading on rear main seal leaks, it looks like the flywheel to crankshaft bolts need thread sealant. I'm pretty sure I didn't use it, but it doesn't seem to be leaking. Just something else to make sure of while the transmission is out. I wish I knew that when I had the ZF out to reseal the input shaft. I'll check/add sealant the next time everything is apart.
Author:  Eck [ Tue Sep 26, 2023 10:55 am ]
Author:  Gunnibronco [ Tue Sep 26, 2023 11:06 am ]
Author:  Eck [ Tue Sep 26, 2023 12:02 pm ]
I’m rethinking this again!
The spot near the main seal does not appear to be wet (just dirty and some probable blowback from a higher leak).
I had degreased as much of the engine I could get to and drove it home from the car wash. The spots that seem to have the most accumulation of caked oil and wet spots are at the rear side of both valve covers and look to follow that path downwards. I also noticed a slight leak at the dipstick tube and it appeared to be a little loose (so I tightened it).
I’m now thinking I need to pull the valve covers and either put in new seals or replace the covers themselves with new seals. I currently have the upgraded blue silicon gaskets on.
Author:  Jesus_man [ Tue Sep 26, 2023 12:10 pm ]
Valve cover vents?
Author:  Eck [ Tue Sep 26, 2023 12:59 pm ]
Author:  ZOSO [ Wed Sep 27, 2023 4:05 pm ]
I had found my cast valve covers like that to be cracked at the bolt holes.
Author:  Eck [ Wed Sep 27, 2023 5:43 pm ]
I am hoping that the real source of my leaks has been 2 main areas:
1. The grommet pictured above. I went ahead and removed the valve covers and ordered new gaskets (although the ones on it looked to be in fine shape). While I had the covers off, I RTV'd the inside of the grommet. It spun freely before and it appeared oil was making its way between the grommet and the valve cover. I also added lock washers to the valve cover bolts.
2. On the other side, once I removed the upper intake, I found that the hose connecting the upper intake to the PCV filter hole in the back of the lower intake had blown completely off the upper intake. I have a feeling that was where a majority of my leaks were coming from. I had been noticing an unusual amount of "backfire" at certain air/fuel/coast/acceleration siuations recently so hopefully this fixes that issue as well. I added a hose clamp to ensure it does not come off again.
In addition, I decided to also change the header gaskets as I felt I was getting some exhaust leaks and also kept having my header bolts loosen up. The gasket I added is suppose to compress up to 50% but will also expand back if needed. It is "guarenteed" to fix exhaust leaks (we will see). I also swapped my header bolts out with some locking bolts that are desgined to NOT loosen up.
Will hopefully have it all back together tomorrow with an oil change and can see if I was successful in diagnosing the major points of leaking. Between the PCV hose not attached to the upper intake, the dipstick tube loose, and the grommet on the other valve cover now sealed-- I am really hoping this captured most of it!!
Author:  Jesus_man [ Thu Sep 28, 2023 10:25 am ]
Hoping for the best!! Remember, with a bronco, you needn't worry until the leaking stops! LOL!
Author:  Justin [ Thu Sep 28, 2023 10:43 am ]
Seems like all of that would at least help. Fingers crossed.
Author:  Eck [ Thu Sep 28, 2023 1:27 pm ]
These valve covers are clearly the source of my leak. The passenger side is by far the worst but the driver side is leaking a little bit too. I think there is a chance they are leaking at the volt holes as they looked to be a little wallowed out.
A junkyard run to grab some stock explorer covers might be in my near future.
I’ve read a little bit on aftermarket covers having issues with roller heads.
Any wise words of wisdom? It’s a 351w with GT40 heads, roller rockers, explorer upper intake and EFI.
Author:  ZOSO [ Thu Sep 28, 2023 6:29 pm ]
stamped steel factory valve covers may not be tall enough to clear roller rockers
Author:  Eck [ Thu Sep 28, 2023 6:56 pm ]
I got a little trigger happy and ordered a set of these:
https://lmr.com/item/SVE-6582B/1986-199 ... f4548ac0f1
Author:  D&D72 [ Sat Oct 07, 2023 3:36 am ]
I have the mustang covers on mine. (not the fancy polished ones) no leaks at all.
Page 14 of 14 All times are UTC - 7 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
