akaFrankCastle wrote:What's your current steering system consist of?
Justin wrote:What's the end goal? Will it be pretty and for running around town or a wheeler?
Digger wrote:Shoot us some pictures of the steering from the front side. When you say it is terrible, does that mean it's loose, bump steer, other, all of the above?
When was the last alignment? Do you have numbers?
mickphatmac wrote:That's a good looking soft top! Wonder where I've seen that before???....
Good looking rig man! Can't wait to see what you do to it ;)
akaFrankCastle wrote:What part of Colorado Springs are you in? I'm by REI.
Digger wrote:I see a couple of things going on.
1) Your draglink is not parallel to the trackbar and not they same length either.
Agree with you on this, I also felt the trackbar looks to be pretty weak, totally different than the others
2) Your steering box is hanging really low and appears to be an angle that is nearly maxing out the rod end at the steer box at static height.
Steering box is shot, looking into a 4x4x2 as mentioned by crawlercreations
3) All the rod ends at the knuckles and pitman arm are secured with bolts. While not certain to have a problem, they are not as secure as tapered studs and can slip if not tight enough.
Didn't catch that initially but it definitly makes me wonder about the quality of work done by the PO
4) The axle side of the track bar appears to be attached to the nose of the radius arm. The radius arm bushings were not designed to handle lateral loads. They get pounded out pretty quick if used that way.
Justin wrote:Jason, you're right, that's a '69-'79 F150 steering box conversion. As has been said, I'd start by ditching that and swapping to a stock power box or a 4x4x2 mounted on the outside of the frame rail. It will meaningfully improve the alignment of the drag link and trac bar. You've got a really unusual radius arm setup. I suspect it's custom, and I'd love to get a look at it in person the next time I go through there. It's wild, whatever it is, but I'm guessing it works fairly well.
The first thing I'd do is find the nearest spouse or 5 year old and have them turn the steering wheel back and forth with the truck off while you climb around under it looking for worn parts. Start by looking at the steering shaft in relation to pitman arm movement. If the shaft moves and the pitman arm doesn't then the box has play. Bolted heims can wallow out their holes, resulting in loose steering as well. Just see what's wiggling under load. It's likely a combination of several things. I might be down that way on the 3rd or 4th if you want help.
