It is currently Thu May 23, 2024 4:48 am
Gunni the ‘66 Bronco
The time has come for me to fess up that I’m the current proud owner of Chad’s 1966. As with a lot of things it was the right truck, I’ve always wanted a “grandpa” Bronco, at the wrong time, Willem had totaled my F-150 hours before Chad messaged me. Anyway, I didn’t waste much time before deciding a new truck wasn’t worth passing on this little gem. I’ve named it Gunni as a nod to its previous owner and town from which it came. Chad has spent a ton of time researching the quirks of the 1st year Bronco and acquiring all the correct parts for this rig. His hard work can been seen in the following threads. viewtopic.php?f=3&t=8062viewtopic.php?f=5&t=8240I’ve spent the last few weeks getting it running and road worthy. The engine needed a little sorting out with electrical, fuel and exhaust. All the lights work, brakes brake and steering steers. The correct, though crusty, interior was bolted in and I had Bobby help me find some AT tires to put on the tiny rims. I also wrestled the twisted bumpers straight enough to mount up. Finally, I pulled the NP435 out and put in a converted top loader temporarily. The grand plan is a restoration with a few period correct additions like a Stroppe roll bar and Rancho overdrive. Also, some safety mods like disk brakes for the Dana 30 and 3 pt seatbelts. The resto is years away, I need to finish Willem’s Bronco, then Declan’s Camaro and BSD always needs a few things. In the mean time I’m going to drive it around Parker and keep it on the road! More to come...
Thu Nov 02, 2017 11:57 am |
TOOLMAN
Re: Gunni the ‘66 Bronco
Nice!
Thu Nov 02, 2017 12:18 pm |
D&D72
Well done! I'm happy to see you got it Kirk!
Thu Nov 02, 2017 12:20 pm |
Strike2
Congratulations on the new ride, its very cool!
Thu Nov 02, 2017 1:51 pm |
I wish I could have kept it. But I'm glad it stayed in the club, and that it will get a restoration, not a resto-moderation. I'm so happy it's back on the road!
Thu Nov 02, 2017 6:21 pm |
BroncoRaider
Joined: Thu Oct 22, 2015 11:47 am Posts: 531 Location: Stapleton
NICE!
_________________ “Buddy” - 1975 Bronco Sport, 302/Viperbuilt 4R70W/D20, Explorer EFI, More Patina than Paint...
Thu Nov 02, 2017 7:24 pm |
I can only hope to follow in your footsteps someday with a "grandpa" bronco of my own. I also got to think of something for my son to drive in 9 years! I look forward to watching you enjoy and then restore this one!
Fri Nov 03, 2017 7:41 am |
I was curious who got it. Great to see it on the road now.
Fri Nov 03, 2017 9:05 am |
cpldavis37
Very cool.
Fri Nov 03, 2017 12:16 pm |
that truck has so much character !
Fri Nov 03, 2017 5:46 pm |
The future looks good for reduced RPM and maybe even 65mph!
Fri Dec 01, 2017 5:16 pm |
I guess 50+ years of use isn’t bad, I just wish it would have broken at home instead of 30 miles away. Good thing I remember how to shift without a clutch, of course the stop lights were a bit tricky.
Fri Feb 16, 2018 5:14 pm |
phyler
Fri Feb 16, 2018 8:18 pm |
D&D72
I think I may have one as well. Lord knows I owe you!
Fri Feb 16, 2018 10:27 pm |
Thanks fellas, already back on the road. I should have known something was up, it was needing more travel in the pedal to get it in gear.
Fri Feb 16, 2018 10:33 pm |
D&D72
Fri Feb 16, 2018 10:34 pm |
rt9
Sat Feb 17, 2018 12:22 pm |
Goodbye lift, Gunni will be just fine without you. Pics when the sun comes up.
Wed Feb 28, 2018 10:45 pm |
Wed Feb 28, 2018 11:04 pm |
So much better with the front lift gone, the PO (not Gunnibronco) that put the lift in did it right, all the items were welded in, serious pain to get it all out without hurting the original parts. Next is pulling the small lift block in the rear, should sit level then. I was a little concerned that the 50+ year old coil springs would sag, but they seem okay.
Sun Mar 04, 2018 9:04 am |
Nice!!
I wondered about those coils as well. It's really coming along. So good to see you breath life back into it.
Sun Mar 04, 2018 10:21 am |
Looks great! How high are the lift blocks?
Mon Mar 05, 2018 8:53 am |
Tue Mar 06, 2018 4:15 pm |
rt9
Looking great!!!
Tue Mar 06, 2018 4:38 pm |
You can notice a slight difference in how the tire is covered. It looks great!!
Tue Mar 06, 2018 5:42 pm |
Tue Mar 06, 2018 7:48 pm |
I’ll see if I can get a part # off of them, if not I’ll measure them and try to find a comparison.
Tue Mar 06, 2018 9:24 pm |
Just something I had wondered about. That front bumper must have weighed a couple hundred pounds, plus the winch. I needed help to get it into the metal recycling dumpster at my neighbor's shop. I don't know what the weight difference between a 170 vs a 302 is.
I think Duff just introduced a 2.5" lift. I'm wondering if it was a 3.5" coil. I bet a measurement and a call to Duff or a post on FB could get an answer. Not really a big deal. I was considering putting them on my 72 at one point. It has an old Superlift lift with coils that look like they belong on a diesel F350. I'm sure it will test the quality of your dental work on a washboard road.
Tue Mar 06, 2018 10:03 pm |
The lift springs measured 18.25 -18.5” free length, a quick search shows 3.5” lift springs have a free length around 20”. Free lengths are based on progressive springs. I’ll send the measurement off to Duff, but right now it looks like a 2” ish lift spring.
Thu Mar 08, 2018 9:09 am |
rt9
Thu Mar 08, 2018 12:12 pm |
