by akaFrankCastle » Tue Nov 10, 2015 12:51 am
casadejohnson wrote:I bit the bullet and swapped my injectors for stage 1's. I was planning on holding out for a while but with a road trip on the horizon I just went for it. I was going to get full force diesel stage1's from Riff Raff but I really wanted the Hydra Chip and Clay does not sell it. I decided to get the injectors straight from Full Force along with the PHP hydra chip. Also, I had 12 cores and Full Force gave me additional credit for my extra cores, Injectors are the same $ either place and they are the same product. I can tell you the truck feels 100% different. Before Installing the chip, I ran it with the stock tune and new injectors and it was a significant improvement over my stockers with 235K on them. My only complaint with the hydra chip is it pumps out more smoke than I would like for daily driving but after talking with Full Force, they are setting me up with additional tunes that will be more friendly for the people driving next to me. The Hydra chip is a 17 position chip so I can keep my ridiculous 140HP smoke cloud tire eating tune for screwing around an still have good usable tunes such as high idle, towing tunes and DD tunes. The other nice thing about the hydra chip is that you can download the tunes or have them emailed to you. If I want to change the tunes on the chip, I can do it from a laptop computer sitting in the driver seat. I"m very interested in how its going to tow now, Improved towing was the goal with all of my modifications. If your on the fence about stock injector reman injectors vs stage 1's, I would invite you to test drive mine. I think the few extra dollars spent is $ well spent
For me, it's about money. If I can get away with a $100.00 set of injectors with $74.00 worth of o-rings for another year, awesome. Too many hungry mouths in my driveway for one of them to be eating a buffet.
Now, that being said...
If these sticks don't work out, things are going to get stupid around here. In a very smokey way.
Stage 1.5s
T500 HPOP
Fuel rail crossover
HP Oil cross over
Wicked wheel V 2.0
New tunes
and 4.56 gears
I don't want to go that route. But it is a necessary route in my mind. And here's my logic.
Reman injectors don't help me in the long run because of my life and tires. Additionally, I have ginormous bumpers. AND a 44 gallon fuel tank about to go into the truck in addition to the 33 gallon main. I need more power to commute effectively. Running reman injectors will only cause/exacerbate issues down the road. i.e. my HPOP will continue to struggle to meet the demands of the injectors, my turbo will log, my rear diff, driveshaft, and output shaft on the transfer case will suffer from the gearing. You see where I am going.
The T500 is not something I need to run the sticks. But, it is something I need to run the sticks AND tow. And this is something I am interested in seeing when you tow Jeremy. Your injectors are going to be hungry. How hungry, I don't know. But I would not be surprised if your HPOP has trouble keeping up with demand. Did Ryan mention anything about high pressure oil concerns when you ordered the injectors/tuner? If you are planning a big towing trip soon, it might be worthwhile to do a test run SOON. Better to find out now than on a pass somewhere.
