New to me 55 f100
For all the Fords that aren't Broncos
New to me 55 f100
Postby JGZ » Mon Oct 07, 2019 8:11 am
Hey everyone. I'm trying to figure out exactly what I have here.Was told it was a Napco conversion, but I'm not sure..Could also be a Marmon Harrington conversion.Or it could be neither.Leaf spring at all four corners and looks to be Dana 44s frt.and rear.If anyone knows about these I'd love to figure it out before I decide what path to take with it.
Thanks Jay
JGZ
Re: New to me 55 f100
Postby Rox Crusher » Mon Oct 07, 2019 4:54 pm
Jay
I don’t j ow what that is precisely but I love it !
Postby 71 Broncman » Mon Oct 07, 2019 7:56 pm
Don't know for sure either but, IH Scouts had Dana 44's front and rear and leaf's on all 4 corners. What transfer case is in it? Scouts had Dana 20's too. Might give you somewhere to start.
Mark.
71 Broncman
Postby pgilbeau » Mon Oct 07, 2019 8:03 pm
That is pretty cool! I don't even know if Ford made a 4x4 back then or if they where all conversions. Might want to check the front axle and see if it has a BOM number, that would possibly tell you what it came from if it was a conversion. Just a caveat, the Scouts didn't get a Dana 44 until the Scout II in '71 or '72.
pgilbeau
Postby 71 Broncman » Mon Oct 07, 2019 8:06 pm
I think I see a tag on the rear axle that may give you some clue as well, if it's readable. Maybe a part # or Mfg. code that will give a clue which brand of truck it was originally installed in.
Mark.
71 Broncman
Postby JGZ » Tue Oct 08, 2019 7:14 am
So I haven't had much time to dig into this.But here's what I think is in it.390 fe motor,T98 transmission, Dana 23 or 24 transfer case and Dana 44 front and rear axels.Need to do some investigation on the axles to see what they came out of.
The body seems to be in very good condition with only a few small spots of rust on the lower door post.(easy fix)Came with boxes of new parts that I have yet to go through.Should be a nice truck if I dont go to far down the rabbit hole.(Is that possible?)
JGZ
Return to F Series
