ZOSO wrote:if it looks like a rear main leak it's not. Most likely the turbo pedestal o rings. While it's running take the oil fill cap off and turn it over. If it blows off there is excessive blow by. the early 7.3 power strokes are non intercooled. Pre 99 has smaller injectors and less power. Some 01's to 03 have PMR rods(weak). Take an inspection mirror and flash light. Look against the firewall at the up pipes to see if there is any soot build up. If there is the gaskets are shot=high egt/low boost. With the higher sulfur content in the fuel causes the orings in the fuel bowl to seep. Fuel filter every 10k miles. Get yourself an obd2 bluetooth reader and the car gauge pro app for android. Allows you to do a buzz test and contribution test. CPS is known to go out. Glow plug relay is weak. A properly working truck should start no matter the temps if fuel is not gelled. I treat my fuel every tank from sept-may. My truck has started just fine at -15 with out being plugged in.
ZOSO wrote:
Another thing is if your not afraid of a little wrenching to make it worth it but look into the 6.0's. A deleted and studded 6.0 is an awesome truck that could run circles around a 7.3.
akaFrankCastle wrote:You said you don't mind body work, right?
http://denver.craigslist.org/cto/4329409488.html
Gunnibronco wrote:It has manual hubs, is that rare, I think I read there are troubles with the auto hubs? Is that right?
aaah1 wrote:That was quick congrats on the truck.
That's a great deal especially for a manual.
Sounds like a speed trap place to get people from out of town. Go to the court date half the time the cop doesn't even show up and it gets dismissed.
ZOSO wrote:Another note about the block heater is Only need to run it for an hour or 2 before you need the truck. I actually built a timer with an outside air temp switch for mine. If its between 2am and 8am and below 28* the block heater will turn on if I plugged it in.
Jesus_man wrote:ZOSO wrote:Another note about the block heater is Only need to run it for an hour or 2 before you need the truck. I actually built a timer with an outside air temp switch for mine. If its between 2am and 8am and below 28* the block heater will turn on if I plugged it in.
Did almost the same thing, but never could get the temp part figured out. Wanted to do exactly what you are doing tho. 4hrs is to have warm air within minutes of driving. 2hrs was long enough for it to start fairly easily.
