7.3 L Woes
For all the Fords that aren't Broncos
7.3 L Woes
Postby Moab Mike » Sat Feb 25, 2017 4:13 pm
About two weeks ago I was driving my 03' F-250 down the road and it began running rough and then got a CEL (code 1316). I was in the process of moving and just decided to get moved and deal with it after the move. I got into the truck on Thursday and found some a-hole decided to try and steal it from me. I replaced the ignition cylinder and finally got it back to square one where I could start it again. I've done the 50 cent fix but I still think it's the UVCH. Any thoughts or ideas?
Moab Mike
Re: 7.3 L Woes
Postby casadejohnson » Sat Feb 25, 2017 7:23 pm
The under valve cover harness kinda sucks to get at. The wires leading up to it can wear through but I'm guessing you already checked the exposed wires for damage or worn insulation. If you suspect the injector drive module itself, I should have a spare that you could borrow to trouble shoot it.
casadejohnson
7.3 L Woes
Postby akaFrankCastle » Sat Feb 25, 2017 9:35 pm
Whip out the multimeter and check resistance at the entry point to the valve cover gasket and harness. Glow plugs should ohm out around 0.8-0.9 each. Injectors should ohm out around 3.6. Anything above 10 or so on the injectors and you need to pull the valve covers and replace the gasket, UVCH, or both.
Add just a little dielectric grease to the pins on reassembly but not too much or you'll wind up crossing a circuit with the goo and have to do this again.
Re: 7.3 L Woes
Postby Moab Mike » Sun Feb 26, 2017 4:07 am
Jeremy I'll get back to you after I ohm out the harness, thanks to both of you.
Moab Mike
Re: 7.3 L Woes
Postby Jesus_man » Mon Feb 27, 2017 8:00 am
First, sorry someone tried to jack your truck! rant I h8 lowlifes like that!!!
Anyway, sounds like you are on the right track. When it does start, how does it run?
Here's a video you may have seen.
https://www.youtube.com/watch?v=GHwjEfJ ... r_embedded
Return to F Series
