I’ve checked fuses and they are good. Blower works but it blows hot air. Anyone know what steps to take to check for why the A/C doesn’t work?
Viperwolf1 wrote:My guess is the compressor isn't turning. Could be clutch problem or no current to activate it. No current could be due to low pressure in the system. There is a pressure switch that will allow the compressor to run only if there is good pressure in the system. That switch could be bad or you may have a small leak.
Eck wrote:Viperwolf1 wrote:My guess is the compressor isn't turning. Could be clutch problem or no current to activate it. No current could be due to low pressure in the system. There is a pressure switch that will allow the compressor to run only if there is good pressure in the system. That switch could be bad or you may have a small leak.
Thanks. Is there a way to check the switch or for a leak? Or to even see if the compressor is turning?
Eck wrote:Tried to jump the switch and I can’t tell if the compressor is kicking on. Air definitely wasn’t getting colder. My multi-meter is dead and I don’t have a battery for it so couldn’t check voltage to the switch.
