Postby kchaser » Wed May 09, 2012 9:05 pm
Bought all the tools to install new gears in my 60's. Took the rear apart, got seriously confused and pissed off. WHY ME! I give up.
kchaser
Postby Friday » Fri May 11, 2012 9:46 pm
Drove it a mile. It's registered and insured just not finished yet. Really gave me the bug to get her done! Can't wait for some warmer days!
Friday
VENDOR
VENDOR
Postby cwin74 » Sun May 13, 2012 5:40 pm
Hit Bill Moore Trail with a co-worker and his full size Bronco. We got fairly close to the lake, but the snow finally turned us back. We decided to go down Red Elephant Hill. I wasn't quite ready for one pucker obstacle, but able to do it with a little scraping underneath. All in all a great run that showed me how capable my current setup is.
cwin74
Postby ZOSO » Tue May 15, 2012 5:11 am
cwin74 wrote:Hit Bill Moore Trail with a co-worker and his full size Bronco. We got fairly close to the lake, but the snow finally turned us back. We decided to go down Red Elephant Hill. I wasn't quite ready for one pucker obstacle, but able to do it with a little scraping underneath. All in all a great run that showed me how capable my current setup is.
I see you've met Matt. I've wheeled with him a few times. He not afraid to push that stock full size either. More pics of your trip on colorado4x4.org.
Postby cwin74 » Tue May 15, 2012 10:58 am
Yep, Matt is on my team here at work. Good guy and he does indeed push that full size Bronco, it has enough rock rash to prove it. =)
A couple of pics, nothing special.
cwin74
Postby kchaser » Wed May 16, 2012 9:36 pm
Have more blood on the garage floor then grease but got the 5:38 gears in the front. Now for the rear...
kchaser
Postby Crazyone » Thu May 17, 2012 8:59 am
Went down and got my collector plates this morning. With the late fees it was $350.00! rant Oh well, I'm good for 5 years now and no emissions.
I got the new CB in and and replacing all the water lines now. Gettin ready for next weekend! fire fire
Crazyone
Postby Entourage » Thu May 17, 2012 9:48 pm
Crazyone wrote:Went down and got my collector plates this morning. With the late fees it was $350.00!
Damn late fees - luckily they max out at $100 as mine was 18 months behind. The 5-year plate is a sweet way to go here in Colorado.
Postby hockeydad4-22 » Fri May 18, 2012 9:18 am
Ordered the twin stick kit for Drew's J-shift. We may be hosting a tech day for installation when it arrives.
That and it looks like a rear axle seal is leaking.... sheesh.... like I have time for that this weekend.
Postby airbur » Sat May 19, 2012 2:05 pm
Completely disconnected the engine, tranny, transfer case, and driveshafts. Socofn is picking up engine and tranny next weekend.
Its amazing how many points the drivetrain connects to other parts of the Bronco.
Sleep, Eat, Train, Repeat
airbur
Postby airbur » Sun May 20, 2012 10:40 am
Pulled the rear OEM fuel tank and all the fuel lines.
airbur
Postby kchaser » Sun May 20, 2012 1:12 pm
Gears are done!!!!
kchaser
Postby airbur » Mon May 21, 2012 12:00 pm
Picked up a '77 J shift D20 today. Bought it off a girl in Littleton who been building an awesome Bronco in her garage for the last 5 years. Very impressive will 5.0 EFI and serpentine. I mentioned the club to her and she joined up.
airbur
Postby socofn » Mon May 21, 2012 2:46 pm
Started disasembly for my swap with the engine from airbur. I decided to pull the front fenders to take care of a couple of rotten areas, what a PIA that turned out to be, I had to get the sawzall and cut two of the bolts and I had to use the big impact gun to remove 5 of the 6 big screws that hold it in the aft position. I had to drill one of them out banghead. I hope to have the engine out by tomorrow night and then get new metal in both holes. Nothing has turned out to be easy!!! JP
74, MONEY EATER
socofn
Postby Rox Crusher » Mon May 21, 2012 2:58 pm
socofn wrote:Started disasembly for my swap with the engine from airbur. I decided to pull the front fenders to take care of a couple of rotten areas, what a PIA that turned out to be, I had to get the sawzall and cut two of the bolts and I had to use the big impact gun to remove 5 of the 6 big screws that hold it in the aft position. I had to drill one of them out banghead. I hope to have the engine out by tomorrow night and then get new metal in both holes. Nothing has turned out to be easy!!! JP
This sounds eerily familiar.
Good luck with your project !
Postby airbur » Mon May 21, 2012 4:08 pm
I was pleasantly surprised that I didn't have beat on any bolts with mine. The toughest ones to get at..and out...where the exhaust manifold to tube bolts. They were seized on there pretty well....had to remove the starter to get one off.
I'm looking for a cheap cherry picker on Craigslist now to pull it.....I'll need it to put my 427W in when it comes time as well.
airbur
Postby akaFrankCastle » Mon May 21, 2012 6:48 pm
I'd run mine up to you but I'm about to lose the turbo in the diesel. Bronco goes back into rotation as the daily driver tomorrow until I can get it pulled and rebuilt.
2 steps forward...
Postby Rox Crusher » Mon May 21, 2012 8:23 pm
I'm looking for a cheap cherry picker on Craigslist now to pull it.....I'll need it to put my 427W in when it comes time as well.[/quote]
You can borrow my cherry picker as I won't be using it for a while (I hope)
Postby airbur » Tue May 22, 2012 7:12 pm
Dropped off the 4R70W with Rox and picked up his hoist.
airbur
Postby socofn » Tue May 22, 2012 7:16 pm
I managed to get both fenders off and then I coated them with some leftover herculiner I had. Still do not have the engine out as my help did not show up and it was 120deg in my garage today so I quit work a before noon. JP
74, MONEY EATER
socofn
Postby airbur » Tue May 22, 2012 7:52 pm
socofn wrote:I managed to get both fenders off and then I coated them with some leftover herculiner I had. Still do not have the engine out as my help did not show up and it was 120deg in my garage today so I quit work a before noon. JP
Yikes! 110 sux.
airbur
Postby hockeydad4-22 » Wed May 23, 2012 5:22 am
Replaced both rear axle seals - everyone is right, so easy a child could do it... Special helper - Tanner, my 4 yr old Nephew.
Tanner scrubbing the mud and grease off the skit plate, brake drum and wheel spacers
Passenger side axle - is this normal? Why do I feel that this Axle is in need of some "special" attention or replacement....
Also - what is with this? It looks like someone welded the ring on - 2 spots, 180* opposite each other. The drivers side is smooth and clean...
Drew adjusting the brakes before installing the drum - nearly done with the passenger side (for now - until we have to replace the axle....
Postby airbur » Wed May 23, 2012 5:36 am
Very nice!!! A family affair:)
airbur
Postby Jesus_man » Wed May 23, 2012 6:38 am
Looks like you've got the same sealed bearings I do. The tack welds appear to be holding the sleeve and bearing on. Shouldn't be necessary if it was the right stuff as that is a press fit. Oil those seals up before you slide the shafts back in.
Postby Jesus_man » Wed May 23, 2012 6:40 am
Pulled front axle apart, carrier out, ring gear off, old locker out, new locker in, ring gear on, carrier in. Awaiting Chromoly's from Trei!
I had to drill the heads off 4 of the 6 bolts holding my locking hubs in on the passenger side. They stripped out! Not to find a new set...
BTW - pretty confident this was my problem and I am glad I didn't try to get to Moab on this:
2 broken pins and one hole busted out, another almost cracked out.
Postby akaFrankCastle » Wed May 23, 2012 6:53 am
[quote="Jesus_man"]
I had to drill the heads off 4 of the 6 bolts holding my locking hubs in on the passenger side. They stripped out! Not to find a new set.../quote]
U Pull and Pay. Take yourself a ziplock bag and an Allen head with you. Grab as many as you want. They're free. Might as well grab a spare set of hubs while you are there too. I got my Warn premiums there for 30 bucks.
Postby Jesus_man » Wed May 23, 2012 6:56 am
I'd love to Zack, but it's hard to find the time to get there. I never did give much though to buying locking hubs there tho...
Postby Kinder » Wed May 23, 2012 10:44 am
hockeydad4-22 wrote: Passenger side axle - is this normal? Why do I feel that this Axle is in need of some "special" attention or replacement....
If it's a stock 28 spline you need I believe I have one. Do you want it before MWFR?
Postby airbur » Wed May 23, 2012 9:08 pm
Hooked up the hoist after removing the carb to get the leveler as low as possible. Kinder came over to pick up some parts and ended up schooling me on xfer case innards:)
airbur
Postby akaFrankCastle » Wed May 23, 2012 9:20 pm
Those levelers look pretty handy. Do they really make pulling and install that much easier?
Return to Chit Chat
