www.ColoradoClassicBroncos.com - View topic - What have you done to your Bronco today? (v.2)
It is currently Sat Nov 23, 2024 3:05 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 34, 35, 36, 37, 38, 39, 40 ... 89  Next
Post Re: What have you done to your Bronco today? (v.2)
Mon Jun 11, 2012 5:28 pm
Tue Jun 12, 2012 9:50 am
Brought this home:
Now to wire & plumb it.
Wed Jun 27, 2012 3:42 pm
Fixed/modified my taillights today. I had a broken one from my recent crawling trip so instead of sticking another 66 taillight lense on it to break eventually I made my own. Definitely not for everyone, but it works for me.
Off
Running lights
Brake/turn/hazards
Tue Jul 03, 2012 6:50 pm
Brought it home. Tucked it away in my own garage. Bet my parents are happy its no longer in their back yard. Got the whole front clip loose crept one screw on the drivers door jam. Gonna have to cut it off. Also turned the motor over by hand. It turns smoothly. Can't wait to get goin on this.
Sat Jul 07, 2012 4:49 pm
Post What have you done to your Bronco today? (v.2)
Finally got the new leaf spring perches from ruff stuff last night, got the d60 centered, pinion angle set, and welded the perches on after bolting it all back together, driveshaft doesn't need lengthening or to be shortened, I guess 3 1/2 inches was the perfect amount to push the rear d60 back, drove it around the block as I haven't driven it in months, runs good with the 410's, just need to find a reamer so I can get the tierod to pull up a lil more into the knuckles
Sat Jul 07, 2012 6:37 pm
Chevy tre's? I have a reamer you came borrow. I'm goin to pueblo Tuesday through Thursday. I can throw it in if ya can't find one down there.
Sat Jul 07, 2012 7:33 pm
No just stock 79 bronco for now, the 76 Dana 44 flat top knuckles I got have use a smaller tre, but I think it's the same taper as Chevy one ton, I'll let ya know, I might have a line on one Monday
Sat Jul 07, 2012 7:50 pm
Should be the same taper 1.5 per foot or something
Sun Jul 08, 2012 12:01 am
Or 7 1/2 degrees I think
Sun Jul 08, 2012 12:50 am
Sun Jul 08, 2012 5:35 pm
Sun Jul 08, 2012 6:11 pm
Sun Jul 08, 2012 8:49 pm
That sounds like it
Sun Jul 08, 2012 10:39 pm
Tue Jul 10, 2012 9:46 am
story man when you called I was on the phone at work. I was already in pueblo by then. I didn't throw it in being I had a day from hell on Monday.
Tue Jul 10, 2012 9:25 pm
No problem man, are you coming down any other time soon?
Tue Jul 10, 2012 11:01 pm
Took it fishin
Thu Jul 12, 2012 9:00 pm
cutting. lots of cutting. making some patches for the rusted out cowl.
Thu Jul 12, 2012 9:08 pm
Picked up my hybrid T/J Viperized D20 today:). Amazing work!
Thu Jul 12, 2012 9:14 pm
Thu Jul 12, 2012 9:16 pm
Fri Jul 13, 2012 9:05 am
It's just the 2.46 T gears combined with the J shift rails and J front output shaft. All the best parts from the Dana factory.
Fri Jul 13, 2012 10:48 am
Decided to see how a power washing would do on the engine bay. It did ok...not great.
Removed the power steering gear and used Aircraft Remover to get rid of the nasty red paint I previously used on it. Going to ship it along with the Explorer pump out to Lee's Power Steering shop for complete rebuilds. They can increase the flow of the pump also and build the hoses I need.
Sat Jul 14, 2012 5:59 pm
Decided I didn't have enough ankle biter issues with the Bronco, so tonight I went ahead and snapped off an intake manifold bolt. I was bored and the gasket R&R was going too well. Haven't figured out whether the reused Mr. Gasket intake bolts or the Harbor Freight torque wrench get credit for the assist.
Sat Jul 14, 2012 11:04 pm
Finally got some time to work on it. Needed to put another bend in the twin sticks to get them to clear the NP435 shifter, so I fired up the new-to-me oxy-acetylene setup for the first time.
Sun Jul 22, 2012 11:52 pm
Sun Jul 22, 2012 11:59 pm
Nothing really......but 76, ZOSO, and booger came by this morning and got the new 7 degree bushings installed, Mike's front drive shaft hooked up and popped in a new chip in the computer. Appears to be running great, handles like a maserati, and is ready to climb Mt. Everest. I thought I did a nice job staying out of the way.
I want to also thank cobshane for fixing that flywheel making a racket after the bolts backed out.
I don't know what I would do without the great guys in this club. One thing I know I wouldn't be doing is driving my Bronco much.
Sat Jul 28, 2012 2:44 pm
Profile YIM
Finally got the steering knuckles reamed, steering installed and got back to driving it last Wednesday, drives great, gotta save up and hopefully in 2-3 weeks can get the rear disc brake kit for the d60, drove it to my buddy's wedding, had to shuffle him around in it for pictures, the photographer was a bronco chick, she wanted to include mine in the photos, I told her probably best to do what the bride wanted haha
Sun Jul 29, 2012 11:17 am
Raptor Liner arrived. Need to finish prepping and repairing the one rust spot.
Wed Aug 01, 2012 6:29 pm
32,974,913 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
