crawlercreations wrote:It is hanging just about level with the link brackets. I'm planning on building a skid plate that covers between all the links and protects the atlas and gives me a flat belly.
or...you could clock it flat....
Jesus_man wrote:crawlercreations wrote:It is hanging just about level with the link brackets. I'm planning on building a skid plate that covers between all the links and protects the atlas and gives me a flat belly.
Strike2 wrote:Looks Great, and those rear mounts are beefy!
I get that with the ORI's you need no bump stops/sway bar but what about limit straps??
Eck wrote:Hurry up. I need you to work on my Bronco!!
Rox Crusher wrote:That looks great Jason
Now fess up...........
You had a garage full of hired help to get that beauty done so fast
TOOLMAN wrote:Were you out for the Golden cruise on Saturday? I think I saw your rig.
Strike2 wrote:Thanks for the updates the Bronco is looks awesome!
So taking the ORI's out the mix (for now) do you think could you feel any difference in the ride quality on the street/trail due to just the rear stretch ??
Jesus_man wrote:Gunni - Let me know if you find a "buy one get one"...we could split the costs!!
I thought there was an e-locker out there for the 9". Will it not work in the hi-9? Since you can unlock the hubs, you could go with any locker up there and not notice it when the hubs are unlocked. And with the Atlas, you can put it in 2WD and still turn sharply off road. Perhaps a Full Detroit would be a good choice? But a solid selectable for the rear would be awesome!
Could you modify your radius arms to work with bushings? I'd be happy to draw you some brackets that someone with a CNC plasma could cut out for you. Actually the Bloody Knuckle site has weld-on brackets & bushings already, but I'd worry the vertical separation isn't enough. I have never looked real close at those arms, but you could also cut off the top mount and then run a second upper arm back to the main arm for pinion angle adjustment?
