It is currently Sat Nov 23, 2024 3:39 pm
Got up before the sun, put on my jacket and DROVE IT TO WORK!!!
First time it has been on the road this summer. (now that summer is over).
Everything seems good so turning her over to Drew tonight to drive till he ships out the end of October.
Tue Sep 30, 2014 11:35 am |
Nice job! Most importantly. Does the stereo work?
Tue Sep 30, 2014 12:16 pm |
Tue Sep 30, 2014 1:27 pm |
That's cool!
Tue Sep 30, 2014 1:34 pm |
picked this up today. Now it'll have heat.
Also started to trace out and label the rats nest so I can clean it up.
Wed Oct 01, 2014 6:04 pm |
Installed the heater blower motor. Also replaced the bolt on the tire carrier. All is good for now. This week will will be a full grease and look everything over before elk hunting.
Sun Oct 05, 2014 4:01 pm |
Gregg
Ordered some bilsteins to replace the shocks from the WH 3.5 lift kit. The lift is only 3 years old and those shocks were crap. After I removed them, I could compress the rear shocks and they wouldn't rebound. The bilsteins improved the street driving a bit but the big difference was a smoother ( not nearly as jolting) ride over some rough terrain. These Bilsteins plus airing down should make the road to Jenny Creek decent. These are the 5100/5125 series. Front 24-065283 Rear 33-186542.
Mon Oct 06, 2014 8:53 am |
Mon Oct 06, 2014 9:48 am |
Moab Mike
Had a new exhaust system installed on the 76'. Got it back today and found out I was Gregged too at the M&G. I now have a pic I can post on the G&L dating web sites! And I have his phone numbers to post too!
Tue Oct 14, 2014 4:46 pm |
Oh, the possibilities....
Tue Oct 14, 2014 5:12 pm |
Gregg
Tue Oct 14, 2014 6:02 pm |
I found some art on my tailgate. Oh art? I meant I found some ass on my butt
Fri Oct 17, 2014 12:53 am |
Finally got around to fixing my sticking brakes on Stroppe'd. When I did my hydro boost/disc swap I failed to clearance the knuckle and caliper enough. This resulted in a hanging caliper but made for one helluva emergency brake. Abrupt stops on the road forced me to hook the pedal and pull it back though. So, with some time to myself yesterday I finally finished the job with my die grinder.
After the brakes were done, I repaired a busted Warn premium that lost a spring and spring lock. Also, I repacked my bearings, seeing as I was already in there.
Sat Oct 18, 2014 2:06 pm |
D&D72
new ducts for the defroster! Driver side was a PITA.
Tue Oct 21, 2014 7:21 am |
Just ordered the tcase rebuild kit. Hoping to get the trans pulled next weekend and the process started of the rebuild/swap.
Sun Nov 02, 2014 9:00 am |
Friday
VENDOR
Joined: Sun Nov 14, 2010 9:24 pm Posts: 160 Location: Palmer Lake, CO
Finally got the engine trans and transfer case installed today. It's one step at a time and someday it will be done.IMG_1833.jpg IMG_1832.JPG
Sun Nov 02, 2014 8:43 pm |
Lookin nice Friday !
Mon Nov 03, 2014 5:45 am |
Now that's one hell-of-a good looking PS Box!!! :):):) Nice work! Keep at it!!!
Mon Nov 03, 2014 8:47 am |
Colorado75bronc
Looks great Steve!
Mon Nov 03, 2014 1:19 pm |
Friday
VENDOR
Thanks guys! Maybe we will have a body on frame party before thanksgiving!
Mon Nov 03, 2014 7:12 pm |
Installed new motor mounts. Unlike the previous owner, I used Loctite and a torque wrench. I can only imagine how much of a PITA it must be when you've got a front axle, headers and inner fenders in the way.
Sat Dec 06, 2014 11:43 pm |
Garry came by this morning and fine tuned the engine. Was having some issues of it stalling where the air idle was a little off. Took the better half for a short ride with no issues. Now I just need to figure out why my heater switch won't turn on to really be ready to drive it this winter.
Sat Dec 20, 2014 3:42 pm |
Is your wiring new or old? My heater fan was melting the solder inside the fuse (not the fuse wire that is supposed to blow). High resistance/rust was causing it. I bypassed the old fuse panel fuse & wired it through an modern inline fuse holder. Just a temp fix knowing I'd rewire sooner than later.
Sat Dec 20, 2014 4:19 pm |
Sat Dec 20, 2014 4:39 pm |
Gregg
At the last breakfast I had Heat Envy out of Robs rig. I think JYD had it too because soon after there was some coolant under the box. Good time to pull the box and give it a refresh. New core, motor, and bigger squirrel cage. I'm going to put it back in before Santa needs his sleigh.
Big thanks to Zoso for the motivation, part numbers and advise.
Wed Dec 24, 2014 11:46 am |
Looks good! It's a big difference. Nice work putting in the antigravity module too. That really makes the defrost effective.
Wed Dec 24, 2014 12:03 pm |
Wed Dec 24, 2014 1:07 pm |
Replaced window felts and tracks and installed new mirror in passenger side door
Then got interrupted by a leaking oil filter so changed the oil
Drivers door tomorrow or friday
Wed Dec 24, 2014 6:37 pm |
Wed Dec 24, 2014 9:26 pm |
I just pull the floor mats out. Those long tube headers everyone seems to hate just warm the truck right up.
Wed Dec 24, 2014 9:28 pm |
Users browsing this forum: No registered users and 9 guests |
