It is currently Sat Nov 23, 2024 3:25 pm
Gregg
I got the refurbed heater box back in without too many "Are you fxxking kidding me?" exclamations. I let it run for a few minutes and Holy Mackerel, it heats up awesome. The high setting sounds and feels like a jet engine. Now if I can keep the back window from mysteriously unzipping, I'll be all set.
Sun Dec 28, 2014 10:34 am |
Sun Dec 28, 2014 10:58 am |
About time you got that finished up.
Sun Dec 28, 2014 11:05 am |
Yesterday I finished up rebuilding the doors.
All new window tracks and felts, mirrors, inner and outer door handles and most of the connectors and clips/hardware in the linkages.
Still need to replace door seals to make shutting the doors easier but I'm afraid I would make it worse based on all the bad reviews on most brands currently available.
Took it for a drive last night and it is so much quiter without all those rattles and wind whistling leaks.
Wed Dec 31, 2014 8:13 am |
Actually from last weekend but had some help from Landshark and his Dad to work on the wiring of Drews dash. I find it amazing how many loose and un-identified wires were spliced into the original (replacement) harness.
Here is hoping that this time we are able to make it easier to ad circuts correctly than via whatever means he used previously
Wed Dec 31, 2014 10:25 am |
I finished mounting up my snow plow today.
It's working real smooth with the rebuilt pump.
While underneath the Ol girl I noticed that the front motor mount bolt on the driver's side is missing.
Sat Jan 10, 2015 6:31 pm |
^ odd, was a lock washer or locking nut used?
Sat Jan 10, 2015 9:53 pm |
Actually finished wiring the dash, Landshark came over and double checked my work, helped me add a few more "future circuits" and got me started wrapping everything up. Then Dan and I put it back in the bronco last night.
new heater motor (chebby upgrade) New defrost ducts (tossed the tapped up dryer vents in the trash) New glove box (silly BH did not have a heavy duty plastic one - just the cardboard so it will have to do) New (to us) intermittent wiper switch (Thanks to Kinder)
Tonight and every evening this week if needed - I will be in the garage making connections to the fuse box under the hood
Cant wait to get it back together and fired up. Make sure everything works so when Drew is home on leave after boot camp - he can drive her
I know - pictures.....
The silly PO's idea of defrost ducts - and they were not attached...... no wonder it did not work for crap
Mon Jan 12, 2015 3:51 pm |
Mon Jan 12, 2015 9:57 pm |
Made the connections to the fuse box last night, I think I have 1-2 more evenings of connections, reinstalling heater controls, lights, steering column etc and time to fire her up! And if anyone has a manual column that they would like to trade for this Auto one let me know (especially if it happens to be a tilt column!) Otherwise I am going to strip the shifter out of this and call it good.
I also need to run wires for the front speakers and make up a couple of good grounds (dash to frame and motor to frame) and I would love to have anyone who is available come over and double check my stuff / help trouble shoot when I attempt to fire her up.
I do have poster size wiring diagrams that are sorta accurate... I can promise the garage will be comfortable - not hot but a hoodie will be plenty warm.
Pictures: The new fuse box I think all that is left is wiring up the relay for the electric fan. After deleting the factory fuse block in the glove box we decided to route everything through the under hood box. Still have room for more circuits! Before:
After:
Yes - Poster size and full color 1974 bronco wiring diagrams are much nicer than the ones in the book!
Oh yeah - and a little glove box door mod:
Wed Jan 14, 2015 7:51 am |
Looks great! hopefully most everything works correctly ;)
Wed Jan 14, 2015 9:32 am |
Very nice!
Wed Jan 14, 2015 10:19 am |
D&D72
Fine job! And I love the glove box door mod!
Wed Jan 14, 2015 2:20 pm |
B.O.B.
Rechecked all my loose rocker nuts and replaced a few. Engine very quite now and hopefully no More problems for a while.
Wed Jan 14, 2015 10:52 pm |
Yet another 27 hrs in the garage over the weekend, and still not ready to drive. But I am that much closer.
Kirk came over and helped last evening and we got the accessories to work via the accessory position on the key. Previously everything was powered all the time because the circuts were on the full time hot buss in the fuse box. We added a relay and some jumpers to non - full (open) locations in the box and now we are all good - I think.
Im not sure what tonight brings, I might be installing a shower door instead of getting this rig road worthy.
Left to do list: Install steering column re-install driver side defrost duct (this might be the biggest pain in the butt left) Install glove box Install stereo tidy up and wrap all the wires coning in/out of the fuse box mount passenger side fender connect the head lights and turn signals double check all connections Bolt the top back down and reattach the wiper motor
Then test everything one more time and toss the keys to our young marine to drive while he is home on leave.
Mon Jan 19, 2015 8:17 am |
got the t case sealed back up and stabbed back in. Got the trans pan sealed up. All thats left is fluids, batteries, driveshafts, and exhaust and she'll be drivable again.
Mon Jan 19, 2015 6:53 pm |
Greg - keep at it!! Can't wait to see the Vroom vroom post!
Rob - all good news!
Tue Jan 20, 2015 4:54 am |
Tue Jan 20, 2015 8:35 am |
B.O.B.
Finally got my synthetic winch rope spooled on my winch. Only sat on the floor of my bronco for 6 months.
Fri Jan 23, 2015 8:54 pm |
Went wrecking yarding to find missing explorer parts. Found an untouched '97. Got upper intake, heater tubes, timing pointer/sensor, tensioner and pulleys. Got to go back in the morning for the timing cover, trans dipstick/tube and blockplate. I did manage to get the fan and balancer off before time ran out. Hope nobody snags that timing cover before I get there.
Fri Jan 23, 2015 10:58 pm |
Since no issues were found with the transfer case I put it all back together this week and finally pulled it out of the garage again. I'll drive it around today to double check everything.
Sat Jan 24, 2015 7:38 am |
sykanr0ng
Sat Jan 24, 2015 3:22 pm |
Moab Mike
Sat Jan 24, 2015 9:09 pm |
Gregg
I suspected the same. I should have taken a closer look with all the sh$t eating grins by the bystanders.
Sun Jan 25, 2015 6:43 pm |
Sun Jan 25, 2015 7:12 pm |
Went to the Upull to grab radius arms. Came home with them attached to a HP Dana 44 with welded wedges and a matching big bearing 9"
Thu Jan 29, 2015 6:44 pm |
Nice. Full width, I'm guessing. Disk brakes?
Thu Jan 29, 2015 7:01 pm |
Sweet, good score.
Drove it to work today. First time since putting it back together again. And what do I find the freakin trans is leaking again. Only leaks when it's been driven and warm. It has sat in the garage the last week and a half and hasnt dripped one drop. Looks like its coming out the vent.
Thu Jan 29, 2015 7:12 pm |
Thu Jan 29, 2015 7:45 pm |
