It is currently Sat Nov 23, 2024 7:03 pm
That club plate is cool !
Sun Dec 04, 2016 6:12 pm |
And still around I believe!
Sun Dec 04, 2016 7:38 pm |
This thing has been leaking oil at rear main and sucking oil into cylinders.
plugs are oily, and oil getting into almost all intake runners, especially # 8 and # 4.
So Phil made a nice baffle for the underside of the intake to try to get it under control.
Replaced rear main too.
Sat Dec 31, 2016 7:38 pm |
cravenbronco
Sat Dec 31, 2016 7:41 pm |
Sat Dec 31, 2016 10:21 pm |
mustangjonny84
Joined: Sun Apr 10, 2016 4:06 pm Posts: 48 Location: Longmont
Put in new (to me) seats. Since I knew the Bronco would be down for a bit, I took the opportunity to freshen up the seats without disrupting my daddy/pickup duties. When I got the truck, it had no back seat and Dodge Durango front seats. The 6-way power seat was nice...but the seats were just not my style. And I bought a used back off of CL and it was just good enough to put the kids' seats in it. I got OEM fronts from a guy who, in addition to a classic Bronco, had a couple Porsches and an NSX (are you on here?). I bought the pearl white covers and white armrests from Tom's and handed it all over to my upholstery guy at work. And I had some white door panels that came with the truck... Before and after rear: Before and after of the OEM fronts: Tried to get a side-by-side with the Durango fronts: The door panels that came with the truck: Then I'll call this the "finished" product....but there'll be more to come:
_________________ 1975 Bronco- 302 w/ EFI,NP435,twin stick D20, D44, D60, 4.5" WH lift, 1" body lift, 35" Nitto Trail Grapplers 2012 Flex Ecoboost - VTA mod 2003 Mustang Mach 1- K&N,SSS catback 1992 GMC Bread Van - wife's food truck... 2003 Suzuki SV1000- GSXR fork,Danmoto cans,carbon fiber fender, lots of stuff painted black 1980 CB750 cafe- GSXR fork,K&N,CBR coil packs,Chappell customs seat,MAC 4/1 exhaust
Mon Jan 02, 2017 10:45 pm |
Looks great!!
Tue Jan 03, 2017 11:20 am |
Started shoveling it out.
Thu Jan 05, 2017 7:20 pm |
Dang! And we were happy with our 1" we got here in IL!
Thu Jan 05, 2017 7:31 pm |
The last 48 hours has been one of the biggest storms I've seen in 22 years in Gunnison. Probably 2.5'. Another similar storm is forecast for early next week too.
Thu Jan 05, 2017 7:40 pm |
Colorado75bronc
Interior looks great Jon!
Tue Jan 17, 2017 7:14 pm |
Breaker 14, Breaker 14.........happy birthday to me !
Fri Feb 17, 2017 12:25 pm |
Working on replacing the power steering pump, steering box and adding hydroboost.
Fri Feb 17, 2017 8:26 pm |
rt9
Wheel bearings. I let eldest do everything. I held the beer. Sent from my SM-G860P using Tapatalk
Sat Feb 18, 2017 8:05 pm |
TOOLMAN
Installed a new WH battery tray after the breakfast Saturday!
Mon Feb 20, 2017 9:56 am |
Realized I posted the wrong progress photo of my hydro swap! waiting on some hose ends and need to pick up the master cylinder..
Working on adding a transmission cooler as well..
Mon Feb 20, 2017 10:21 am |
TOOLMAN
Started putting the cage together last weekend....
Mon Feb 27, 2017 3:50 pm |
Daaaanng, nice welding table
Mon Feb 27, 2017 4:36 pm |
Mon Feb 27, 2017 5:19 pm |
Mon Feb 27, 2017 10:02 pm |
TOOLMAN
Tue Feb 28, 2017 8:18 am |
TOOLMAN
Tue Feb 28, 2017 8:22 am |
Sat Mar 25, 2017 9:55 pm |
Sun Mar 26, 2017 4:23 am |
BOBS 2 68S
Got the new seat belts installed.
Sun Mar 26, 2017 5:17 am |
Mon Mar 27, 2017 6:19 am |
Mon Mar 27, 2017 11:55 am |
Mon Mar 27, 2017 12:01 pm |
Do we need to send the CCB intervention team out?
Mon Mar 27, 2017 1:45 pm |
casadejohnson
Pneumatic sheers cut that sheet metal like butter.... won't even scuff the paint.
Can't cut the back and not the front. Go big or go home!
Mon Mar 27, 2017 8:52 pm |
