It is currently Sat Nov 23, 2024 6:39 pm
Wed Mar 29, 2017 12:32 am |
TOOLMAN
Got the cage finished this weekend and everything put back together....
Tue Apr 11, 2017 7:09 am |
Strike2
Very nicely done
Tue Apr 11, 2017 12:06 pm |
Tue Apr 11, 2017 12:28 pm |
with nice rockers!
Tue Apr 11, 2017 1:31 pm |
TOOLMAN
Tue Apr 11, 2017 1:37 pm |
Tue Apr 11, 2017 1:40 pm |
TOOLMAN
Tue Apr 11, 2017 4:06 pm |
Flipped my battery cables around to get ready for summer... Sent from my iPhone using Tapatalk
Thu Apr 20, 2017 7:28 pm |
Ordered an intank kit for the fuel pump from sunset fab. Will have to order a pump and a hydramat sock for it. Plan to weld in the shock hoops this weekend and measure again for shocks. Get that order out to bilstein. Then pull the radiator and balancer and get that all re done again.
Fri Apr 21, 2017 5:16 pm |
Fri Apr 21, 2017 7:02 pm |
Ordered my 14in short body 7100's with custom valving from Lee at raceshock. Should get those in 2 weeks.
Thu Apr 27, 2017 8:25 am |
Thu Apr 27, 2017 10:46 am |
Testing a new part. 20170427_185534.jpg 20170427_185540.jpg 20170427_173340.jpg
Fri Apr 28, 2017 9:54 am |
What is the new one out of? What are the differences in specs?
Fri Apr 28, 2017 10:38 am |
Fri Apr 28, 2017 2:23 pm |
Want. It'd wake my ram up.
Fri Apr 28, 2017 9:09 pm |
Sat Apr 29, 2017 6:54 am |
This project took a lot longer than I was hoping. Improvisation was my word of the day. I think it turned out fairly decent considering it really never wanted to fit the entire day.
Sun Apr 30, 2017 7:25 pm |
rt9
Started a new project today. This should be nice. Sent from my SM-G860P using Tapatalk
Sat May 13, 2017 5:56 pm |
rt9
Installed and about to do plumbing. Really looking forward to this. Sent from my SM-G860P using Tapatalk
Tue May 16, 2017 8:54 pm |
Brought her home!!!
Then I have taken her out for a spin to town a time or two! I need to check to see if any of my indicator lights work as I suspect they don't, but it's good to be driving the ole girl again!!!
Mon May 29, 2017 6:54 am |
That has to feel good !
Mon May 29, 2017 7:11 am |
Finally got my 14" 7100 short bodies. Custom valved at 345/135D.
Wed May 31, 2017 7:37 am |
Finally got a minute to work on the Bronco
Replaced the stock spare tire mounting hardware with a plate I got from battlement fab.
Sat Jun 03, 2017 1:40 pm |
What a long hot day in the garage. Good news is I'm 95% done. Should fire up mid morning.
Sat Jun 10, 2017 10:43 pm |
Sat Jun 10, 2017 10:54 pm |
cravenbronco
I was finally able to get the ugly farmers bumper off the front end of the 66 halfcab. Now all I have to do is box the frame and where my new to me snow plow mounts up. Like usual I'm sure it will turn into a bigger list. But no more ugly farmers bumper.
Sun Jun 11, 2017 5:32 am |
Fri Jun 16, 2017 7:49 pm |
Glad to see you're getting the roof fixed. Here are a couple examples of automatic relays I was talking about: Blue Sea Systems 7611: Sure Power 1315A Cole Hersee 48530 WirthCo 20092 Of course you can wire in a standard 30amp relay as well and drive it off an ignition feed. Here is a diagram for a dual battery setup. In this case, the 2nd battery is on the trailer with its own fuse already. You would fuse at 20-30 amps and wire with 12ga.
Fri Jun 16, 2017 9:45 pm |
