It is currently Sat Nov 23, 2024 2:00 pm
Does anyone know what this is?
Thu Jul 26, 2018 4:38 pm |
phyler
Thu Jul 26, 2018 4:56 pm |
Thu Jul 26, 2018 8:18 pm |
BOBS 2 68S
Got the rebuilt motor done and installed. I did rings, main, rod bearings, cam, lifters, rockers, timing chain and gears. And heads rebuilt by Western Machine
Fri Jul 27, 2018 4:34 am |
Fri Jul 27, 2018 7:30 am |
Getting ready for the Buena Vista Bronco Blitz next week...........
This old school Delta tool box (when they used to be made of steel) popped up for sale on my local FB community page for 25 bucks. Guy used it in this very spot on the EB he sold.
I made a little support frame / stand for it to create storage under neath of it.
Just need to get a duffle bag for the recovery straps and I will be all set.
Sat Jul 28, 2018 9:43 am |
phyler
Thanks to Strike2, got the master cylinder replaced. What a difference. I had so many issues bleeding the system when I swapped to disc brakes up front. The pedal felt better just after bench bleeding the master. Only took 3-4 pumps in each wheel to bleed the air out. Pedal is nice and firm now. Can't wait to test drive it now!
Sat Jul 28, 2018 1:59 pm |
BOBS 2 68S
It's more like what the Bronco did for me. About 100 miles after rebuild it broke a rocker are stun on #7 exhaust. Could the double valve springs be to much for the stock studs.
Sat Jul 28, 2018 7:29 pm |
Sun Jul 29, 2018 7:33 am |
Brought the 77 home to my garage. Will be cutting this tub up the weekend after the bronco blitz. https://youtu.be/EnD_18EM8AA
Sun Jul 29, 2018 12:49 pm |
Your tetanus up to date Rob?
Sun Jul 29, 2018 1:20 pm |
Sun Jul 29, 2018 4:45 pm |
Sun Jul 29, 2018 6:51 pm |
Sun Jul 29, 2018 7:45 pm |
Took mine wheeling at Flat Nasty. Another successful trip free of fuel issues!!! Got myself stuck between a rock and a hard place here. Had to winch to get rear to clear tree and then back out. I made this obstacle once! Then I decided to try the line to the left: https://photos.app.goo.gl/49uwCFqxHRzoRvvz7Great time and while it was still warm being in the upper 80's and humid, it could have been MUCH hotter!
Mon Jul 30, 2018 7:49 am |
D&D72
[quote="Jesus_man"]Took mine wheeling at Flat Nasty. Another successful trip free of fuel issues!!! Then I decided to try the line to the left: https://photos.app.goo.gl/49uwCFqxHRzoRvvz7This album says it is empty
Mon Jul 30, 2018 9:07 pm |
Tue Jul 31, 2018 6:04 am |
Winch by Wednesday ?
Tue Jul 31, 2018 5:21 pm |
Tue Jul 31, 2018 9:44 pm |
D&D72
Tue Jul 31, 2018 11:03 pm |
cravenbronco
Had to do a little paint and body work. But as I flipped the fender flare over I couldn't help but laugh. All because I know who made these. Thanks Jay. There still holding up great.
Wed Aug 01, 2018 3:04 pm |
Wed Aug 01, 2018 5:49 pm |
I’m not slow........I’m methodical
Wed Aug 01, 2018 5:50 pm |
Thu Aug 02, 2018 7:46 am |
Gregg
Thu Aug 02, 2018 11:32 am |
Nice work Jeff! It hides in there nicely and sits low for better pulling angles. You have cable or rope for it? How does it attach to the drum? First time I used mine, the whole rope spun on the drum and would just spin. I ended up putting grip tape on the drum. Also, if rope, don't wrap it nice and neat. The first time you use it, it'll suck the line down deep into the other windings and bind it up. You want to wind it up by going across the drum pretty quickly.
Thu Aug 02, 2018 11:45 am |
Fri Aug 03, 2018 3:19 am |
One big project done and then 30 little projects while I procrastinate the next big project... License plate install... little project I always liked the idea of the Wyoming bucking Bronco and pair that with the ‘68 YOM plate :)
Fri Aug 03, 2018 10:37 am |
Sat Aug 04, 2018 4:43 am |
Mon Aug 06, 2018 6:17 am |
Users browsing this forum: No registered users and 9 guests |
