It is currently Sat Nov 23, 2024 11:31 am
This post should be titled... What has your Bronco done to you Today!!!???
My peeps on EBay are almost Literally giving these “Old Ford Horns” away...this one’s in better shape than the 1st.
Tue Aug 14, 2018 11:05 pm |
Made the worm gear switch without a hitch... add a little paint... 4x4x2
Tue Aug 21, 2018 8:37 pm |
phyler
Added a bit of paint. Pretty pleased with it. Single stage but I got it to cover nicely once I dropped to a 1.2 tip. Hope to do more next weekend. Sent from my Pixel 2 using Tapatalk
Sat Aug 25, 2018 3:00 pm |
mustangjonny84
Joined: Sun Apr 10, 2016 4:06 pm Posts: 48 Location: Longmont
Did the rattle-can special on the top of my top. It's not pretty. I just wanted prettier and needed something to last until spring. Two cans of white primer and four (8 oz.) cans of Wimbledon White. Before: After:
_________________ 1975 Bronco- 302 w/ EFI,NP435,twin stick D20, D44, D60, 4.5" WH lift, 1" body lift, 35" Nitto Trail Grapplers 2012 Flex Ecoboost - VTA mod 2003 Mustang Mach 1- K&N,SSS catback 1992 GMC Bread Van - wife's food truck... 2003 Suzuki SV1000- GSXR fork,Danmoto cans,carbon fiber fender, lots of stuff painted black 1980 CB750 cafe- GSXR fork,K&N,CBR coil packs,Chappell customs seat,MAC 4/1 exhaust
Sun Aug 26, 2018 8:32 pm |
phyler
Sun Aug 26, 2018 8:43 pm |
Success in my book!
Mon Aug 27, 2018 7:45 am |
cw72
Joined: Sun Jul 08, 2018 9:04 am Posts: 113 Location: Denver, CO
Went exploring! Sent from my iPhone using Tapatalk
Mon Aug 27, 2018 5:07 pm |
Cool shot! Where is that?
Mon Aug 27, 2018 5:58 pm |
cw72
Twin lakes area. Peek a boo gulch. Directly to the right of that photo was an old mineshaft. We think it’s connected to Winfield.
Mon Aug 27, 2018 9:53 pm |
I'll have to look that up! My family owns some mining claims in the area, so we've traversed a fair amount of those mountains, but I certainly don't recognize that area.
Tue Aug 28, 2018 10:00 am |
Got the lower Radiator hose made.
Thu Aug 30, 2018 6:26 pm |
Fan (cravenbronco), radiator (cpldavis37), and shroud installed...
A Big thanks to all the members who are always giving me a hand!!!
Wed Sep 05, 2018 11:25 am |
BOBS 2 68S
So got back from hunting this week ( buddy got a deer ). The new motor in Red sucks! And I don't know why. It fell on it's face under a load or hill. Outside of Fairplay I found the distributor clamp was loose, just cranked in some more timing. It helped so in Poncha Springs I added some more timing. Better but still sucks, but left it alone until I got home. On the way home it started running warmer and warmer and warmer. Water pump died, leaked out most of the coolant. New water pump. Checked the timing no where near the timing mark. Put it back to my timing mark and pig city. Put it back where I had it while hunting. No idea what I did in the rebuild. Set cam at zero. After after all my crying. Red got a new water pump.
Sun Sep 16, 2018 6:59 am |
Sun Sep 16, 2018 7:16 am |
BOBS 2 68S
Dist off a tooth. Didn't think of that, it would start right up after all the other valve train problems. Maybe advance it a tooth? I will take a "brave pill" and make a adjustment.
Sun Sep 16, 2018 4:03 pm |
Mon Sep 17, 2018 6:12 am |
TOOLMAN
Got my bumper project pretty much completed!
Mon Sep 17, 2018 1:41 pm |
Strike2
Bumper looks Awesome! The old school Coleman cooler is a nice touch.
Mon Sep 17, 2018 2:09 pm |
Y'know I think there is a market for a better performing "retro" cooler. Those old coolers are cool, but they just don't perform as well as some of the stuff out now.
Mon Sep 17, 2018 3:01 pm |
Mon Sep 17, 2018 4:53 pm |
Tue Sep 18, 2018 3:54 pm |
After I got all this together as reported nine posts ago, I was obliged to steal or better yet copycat the suggestion from Viperwolf1 to BroncoRaider to substitute a trailblazer heavy duty clutch fan in lieu of the explorer fan clutch. I was also able to use the plastic fan, I did not have to use or purchase a metal fan for this application.
It moved the fan foreword at least an inch, if not more and now the fan isn’t too good for its home!!!
Nice mod gentlemen! ThankYou:):):)
Tue Sep 18, 2018 10:16 pm |
I spent some time making ‘79 parts play nice with ‘68 parts and then when I got bored I had to mess with one of my fun projects... if it’s unique, I got it! (or I’m getting it)
I had to cut a little groove in the column support on the firewall so the automatic shift lever would go down into first, otherwise neutral was as far as it would go down.
‘79 tilt Automatic Column
Wed Sep 26, 2018 3:11 pm |
love those rain window vents
Thu Sep 27, 2018 7:15 am |
Welded a few braces to the radius arms. Feel a lot more comfortable driving it now. Drove it the first time since the August trip. Will drive it to the Platte meet.
Sun Oct 07, 2018 6:26 pm |
crawlercreations
Time to try out stickies. Found a great deal on some used krawler 39" stickies and stazworks double beadlocks. I'll throw them on the bronco for the harder trails and see how I like them. If they're as good as everyone says I'll likely sell them and the 40" mtrs on the bronco currently to buy new sticky krawlers to run full time.
Wed Oct 10, 2018 10:13 am |
Interested in your take! Sounds like stickies are the cat's meow!
Wed Oct 10, 2018 10:25 am |
These are Not sticky, but they Are NEW!!!
Maybe get them mounted this weekend!?
Wed Oct 24, 2018 9:26 pm |
Those will look nioce!!!
Thu Oct 25, 2018 9:19 am |
I got the three wheels that are the same size cleaned and painted, and I have 2 tires mounted and on the Bronco and the best tire from the previous set mounted as my spare...
Sat Oct 27, 2018 7:57 pm |
Users browsing this forum: Google [Bot] and 7 guests |
